Old 10-20-2014, 10:57 AM   #1
Fraubear
fraubear's Avatar
1968 17' Caravel
Noblesville , Indiana
Cracked Aluminum Wheels on 2004 Classic
As we were getting ready to leave the campground and head for Death Valley I noticed this (attached image).
Not only was this wheel cracked all the way through, but ALL the wheels were beginning to fail on a 2004 30' Classic. Has anyone else seen this kind of failure? We'd like to figure out the cause and avoid it in the future.
Good thing we saw it before we left or the "death" in Death Valley could have been taken literally.
Thanks for any feedback.
Carolyn
fraubear is offline   Reply With Quote
Old 10-20-2014, 11:08 AM   #2
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Yes, on our 3/4 ton Suburban. I bought these Alcoa "Sport" wheels and received a letter from Alcoa that they were being recalled for the exact problem I see in your picture. They replaced all for wheels on our Suburban.
If I remember right, you'll need to remove the wheels and there is a 6 or 8 digit number on the inside. You'll need those numbers when you contact Alcoa for replacement wheels.
Good luck
subfan1 is offline   Reply With Quote
Old 10-20-2014, 11:22 AM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Oh my goodness gracious me! (The Shirley Temple version of what I really said!)
I am so glad you spotted that. It's something I never would have even thought of looking for, but might have run across while checking tire inflation. OMG there are two Classics of about your vintage at my current camp. I think I'll do an informal inspection of both today!
Paula
Old 10-20-2014, 11:26 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Since you are going to be getting four new wheels anyway, you might as well use the opportunity to get 16" wheels and put LT tires on them rather than just getting new 15" inch rims with trailer tires.
Bob Martel
WBCCI# 5766
Old 10-20-2014, 11:28 AM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
As a safety precaution, I ALWAYS add tires and wheels to my pre-trip inspection. While I am checking air pressure I look at my wheels while I am there.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 10-20-2014, 12:31 PM   #6
Fraubear
fraubear's Avatar
1968 17' Caravel
Good luck
Thank you, thank you, for the information. We'll be contacting Alcoa toot sweet. When did you receive the recall notice?
Old 10-20-2014, 01:13 PM   #7
Fraubear
fraubear's Avatar
1968 17' Caravel
We just talked to Alcoa (thanks to your replies, which gave us hope), but alas while they recalled the 16" wheels that failed, they did NOT recall the 15" wheels. Back to Big O in Pahrump NV for some steel wheels that will take us through the winter out West. Our 15" tires are still in good shape, but once they go, we're opting for the 16" wheels and Michelin. Seems to be the way to go.
At least we know it wasn't our fault. Thanks to all.
Old 10-20-2014, 01:24 PM   #8
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Consider taking the plunge, go to 16's now if you can.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 10-20-2014, 01:52 PM   #9
TahoeStream'n
subfan1's Avatar
Our Suburban was. 98 with 16 inch wheels. The recall was in early 2000s however it was the same design as your wheels. Did you have the serial numbers when you called them?
I would have asked to speak to a supervisor because the issue was the exact same description as in the photo. If they don't cover them, that's a bunch of BS!
Sorry it didn't work out for you. Like the other posters have said, go to the nearest discount tire and upgrade once. No need to add to that expense if your going to do it anyway.
Old 10-20-2014, 03:16 PM   #10
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I had the same situation on a 2005 Classic that we bought used about 5 years ago. Mine were not cracked right across the web although I suspect they would have been before much longer.
I found them one day when polishing the wheels - cracks were progressing inward on several webs about a half inch on each side.
This was on both rims of the back axle.
At the time, I contacted Alcoa and to my surprise, they were still "JUST" within the warranty (5 years as I recall?) and they would take care of me even though I was not the original purchaser.
At first they told me that the wheels were no longer manufactured and it seemed as though they were going to send me four new wheels of a different style.
I was happy about that because I had noticed that the originals were rated at 2200# whereas the GVW at 10,000# didn't give much or a margin and I figured I would upgrade to heavier rims.
To my dismay, they were able to find two NOS rims from a dealer so that is what they finally sent to me.
I watched the rims very closely after installation and never saw a repeat problem - and the front axle rims were always fine.
I have since upgraded to 16" Michelins and rims rated at 3200# each. I would recommend going that route as I think the originals were somewhat marginal.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 10-24-2014, 06:13 PM   #11
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
fraubear - In May I upgraded my running gear which included the 16-inch wheels and Michelin LTX225/75R16(E) tires at JC - they had a special around $360 per set (I bought 5).
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 10-24-2014, 08:32 PM   #12
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I would agree with that recommendation. Great idea. If you choose to do that, I'm sure you will be glad you did.
Ken
Old 10-24-2014, 08:42 PM   #13
withidl's Avatar
2002 31' Classic
Houston , Texas
Been There, Done That
I had one of the wheels on my 2002 ASCL 31' fail along the inside center such that the tire went flat from the air leaking through the crack; I put the spare on and continued my trip to Oshkosh. On my way back to Houston I stopped by Jackson Center for some maintenance and told them about the wheel failure. They replaced it with one from their inventory at no charge.
withidl is offline   Reply With Quote
Old 10-24-2014, 09:18 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have wondered about the alum wheels for this sort of problem.
But it could happen to steel as well.
I wonder how the steel would react to overloading if this was the cause of the cracking.
Peace and Blessings..
Channing
WBCCI# 30676
Three original Alcoa wheels from 2004 Classic JimAspinwall Airstream Classifieds 0 09-13-2014 10:08 PM
2013 30' Classic has cracked fluorescent light covers m.hony 2011 - 2015 Classic (all lengths) 5 11-13-2012 06:28 AM
cracked fluorescent light covers in 2013 30' Classic m.hony Lights - Interior & Exterior 4 10-17-2012 12:27 PM
345 MO 1986 aluminum wheels, why are my rear inner wheels steel ? moonshine Classic Motorhomes 6 12-09-2009 05:31 AM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
