Old 11-27-2009, 05:36 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Correct wheels for 65 Ambassador
I have bought a 1965 Ambassador I am picking up next week.The owner is towing about 500 miles to meet me and I have another 300 home.
The trailer has split rims with new tires.I am no crazy about the split rims.
He said he had 5 Airstream wheels with tires for a good price(maybe use one as a spare)How do I tell if they are genuine Airstream wheels with the correct load rating(not car wheels)?
Also when was the baby moon used on new trailers?I think they really give a more vintage look with some I have seen with color painted rims.
bwaysteve is offline   Reply With Quote
Old 11-27-2009, 07:16 PM   #2
Usually, a wheel rating is stamped on the inside. Once a tire is mounted on it, you cannot see it.
Old 11-27-2009, 07:48 PM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
weight rating
Andy,
I assume I would be looking for 2600lb. rating ?
Old 11-27-2009, 08:15 PM   #4
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
I have seen this place mentioned in past posts. I have no personal experience with them. Dexstar Wheel Company Trailer Rims and Wheels.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-27-2009, 08:56 PM   #5
Andy,
A wheel rating of at least 2600 pounds, is necessary, for several reasons, a couple of which are, the trailer loads that are impossed on them.
Another huge reason is sidewall strength. Making a tight turn with a tandem or tri-axle, puts huge loads on the wheels.
Most owners have never seen the twist that 2 or 3 tires on one side of their Airstream can have. They have enough force in them that if you dared to unhitch, with the tires in a twist, the tires will make the trailer swing sideways with tremendous force, enough that if the A-frame hits you, you could be severely injured.
Old 11-27-2009, 09:07 PM   #6
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
thanks
Thanks Lee for the link.
Old 11-27-2009, 10:07 PM   #7
Kevin245's Avatar
If you look at wheels for use with baby moon hub caps there are two types to consider. There's the old style wheel with riveted spring clips and there's the newer Nub style. The hub caps for each style are not interchangeable.
My 73 Avion has the riveted spring clip wheels which are shown in the first photograph below. The other photo shows the nub style wheel.
Congratulations on your Ambassador.
Kevin
Eleanor Roosevelt
Old 11-27-2009, 10:15 PM   #8
1967 22' Safari
1960 Caravel
Images: 8
Kevin
Kevin, Do you know of a vendor that still sells the old style wheel with riveted spring clips? My 60 has the old style and I've been asked about them and I don't have a new source for them.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 11-27-2009, 10:18 PM   #9
To the best of my information, the old style wheels with hub caps clips on them are obsolete.
It's too much labor to install the clips.
Old 11-27-2009, 10:25 PM   #10
1967 22' Safari
1960 Caravel
Images: 8
It to too much labor to install the clips.
That fits with the information that I have too Andy, but once and awhile a new source comes up.
It never hurts to ask and sometimes you are pleasantly surprised.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 11-27-2009, 10:30 PM   #11
I will check with some of our old time suppliers and see if maybe they have any stashed someplace.
The end and the first of the month is always a bearcat for me, so it may take a few days.
Old 11-27-2009, 10:31 PM   #12
Kevin245's Avatar
I don't know of a supplier either . I seem to recall some older threads where someone mentioned installing the clips themselves but I don't think that is something I would do.
Kevin
Eleanor Roosevelt
Correct Wheels "78" Ambassador Roadrunner Wheels, Hubs & Bearings 2 09-21-2009 03:14 PM
Wheels for a "68 Ambassador JokerDJD Wheels, Hubs & Bearings 2 08-09-2009 09:29 AM
Correct wheels and offset bhayden Wheels, Hubs & Bearings 2 06-25-2007 01:45 PM
1967 28' ambassador wheels/rims hazhoni Tires 2 09-15-2006 07:02 PM
cORRECT FACTORY WHEELS? Cedars Wheels, Hubs & Bearings 2 12-23-2003 07:10 AM
