Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Old 09-21-2009, 02:44 PM   #1
Profile:  1978 29' Ambassador
Indiana , Pennsylvania
Correct Wheels "78" Ambassador
I'd like to replace the steel wheels on our "78" 28' Ambassador with nice aluminum wheels. I know they are 15" and have 6 lugs...what else do I need to know. Or does anyone on the forum know the correct wheels to use. Thanks!
Roadrunner is offline   Reply With Quote
Old 09-21-2009, 04:01 PM   #2
Profile:  1967 26' Overlander
Winston Salem , North Carolina
Images: 101
I think you will need:
15" 6 lug 5.50 with zero offset
Greg
Winston Salem, NC
WBCCI 5218, Piedmont NC Unit 161
1967 Overlander International.
FTC 15771
1979 Avion 30ft rear bath
Silverwanabe is offline   Reply With Quote
Old 09-21-2009, 04:14 PM   #3
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Greetings Bob!
The detailed specifications include:
15" X 7"
6 Lug
5.5 on Center
Offset = 0
Overall Width = 8
4.28” Center Bore
2600 LB (minimum capacity).
Max PSI-at least 65
I used these specifications when ordering new aluminum wheels for my Overlander and they worked out beautifully . . .
Good luck with your research!
Kevin
Kevin D. Allen
AIR #827
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 50 10-11-2009 09:14 AM
Wheels for a "68 Ambassador JokerDJD Wheels 2 08-09-2009 10:29 AM
"new" '63 Ambassador repair questions campbell Member Introductions 7 04-14-2007 09:04 PM
Hubcap search -- looking for "dog bowl" or "baby moon" hub caps yukionna For Sale & Wanted 5 07-26-2004 05:44 PM
