Old 05-29-2004, 07:13 PM   #1
Cracker's Avatar
Pittsfield , Maine
Correct Torque for wheel lug nuts?
Can anyone provide the correct torque for the wheel nuts on my 2000 Excella?
Found it - 80 ft. pounds for the forged aluminum wheels! I didn't think that it was in the Owners manual but after I made the post I checked and it jumped right out at me.
As Lily Tomlin would say - "Never mind!"
Cracker
Cracker is offline   Reply With Quote
Old 05-30-2004, 08:53 AM   #2
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Be sure to recheck after the first 100 miles. Aluminum wheels some times need to seat and the lugs will loosen as a result.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-30-2004, 09:24 AM   #3
Cracker's Avatar
Pittsfield , Maine
59toaster:
That's a good point to post ever so often. I just invested in a torque wrench and the correct sockets, extensions, etc. to permit me to check both the lugs on the truck as well as the trailer. In checking the duallies on the truck in the past - at a GM dealer - I've found them to be considerably off torque after only 1500 miles of driving. Duals apparently work one against the other to loosen the nuts. Since I do a 7-wheel rotation every 7,500 miles it's a lot easier to own the torque wrench than to go back to the dealer every time - if I'm still anywhere near the dealer!. Some dealers will look at you like you're nuts when you tell them you want to check the lug nuts with a torque wrench - and I haven't found a single GM dealer so far that knew what the correct torque was suppose to be. Truth is, most tire men use the same air-drive torque wrench for everything they're working on - with no thought to torque settings.
Cracker
New Owners: Make sure you torque Lugs... hohne Tires 32 03-27-2004 02:54 PM
? correct way to measure A-T want310 Airstream Trailer Forums 2 01-29-2004 03:40 PM
Hitch ball torque APB Hitches, Couplers & Balls 2 02-24-2003 05:13 AM
Correct color of bumper and tongue gmc70 Clearcoat, Exterior Paint & Trim 2 06-24-2002 06:19 PM
