Old 11-01-2011, 01:50 PM   #1
Denbear's Avatar
1975 27' Overlander
Eugene , Oregon
Correct size wheel for '75 Overlander 27'
My '75 rides on 225/75R15's. Is 15x6/ 4.25 cross bore/ 0 offset the correct size of the wheels? Damaged a steel wheel & about to order alum replacements.
Denbear is offline   Reply With Quote
Old 11-01-2011, 02:31 PM   #2
You have the correct info above.
Old 11-01-2011, 02:36 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The wheels are 15x6 with 6 lugs on a 5.5" circle, zero offset.
— David
Old 11-01-2011, 03:11 PM   #4
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Would this be the same for a '72 Overlander?
tphan is offline   Reply With Quote
Old 11-01-2011, 03:13 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Yes, although the wheels themselves are slightly different. In 1972 the wheels n the trailer usually had clis for baby moon hubcaps.
Old 11-01-2011, 03:27 PM   #6
Denbear's Avatar
1975 27' Overlander
Eugene , Oregon
The wheels I'm ordering require an additional center cap. Is 4.25 the correct size?
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Split Rims gotta go, is this a correct replacement? Tabasco Wheels, Hubs & Bearings 20 03-23-2012 01:48 AM
The correct Elevator bolt size is? Top Repairing/Replacing Floor &/or Frame 17 11-30-2011 07:20 AM
Need wheel, and wheel cover oldcar29 Wheels, Hubs & Bearings 4 07-05-2011 02:09 PM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
