Old 11-09-2014, 01:02 PM   #1
1975 25' Tradewind
Biddeford , Maine
Converting from lug bolts to studs and lug nuts
Hi All,
I have a 1975 Airstream Tradewind as of two weeks ago. The first item I purchased for is was a new set of galvanized steel wheels, tires, center caps, and lug nuts. Oops... didn't even realize I needed lug bolts. So, now I'm leaning towards keeping the nuts and converting from bolts to studs.
My question for anyone who has does this before: Do you think this one would work: https://www.trailerandtruckparts.com...0-_p_1132.html
Or, if you have a better source, let me know. I've read some posts about people buying studs that are too long or too short, so I want to try to get it right on the first order.
Thanks for the help.
tim781996 is offline   Reply With Quote
Old 11-15-2014, 11:10 PM   #2
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
stud installation
That looks like a good price, check the shipping cost. Also make sure both ends are threaded 1/2x20, some are not.
I have a '77 Argosy and '08 factory alloy wheels which have recessed holes for the lug bolts so I needed the long bolts just replaced mine with the following parts from Trailer Parts Superstore
24 Long Chrome Lug Nut, 1/2"-20 Thread #90052 $35.76
24 1/2"-20 x 2" Screwed-In Trailer Wheel Stud #ST-500 $45.36
Shipping $14.26
Total $95.38
Put red thread locker on the short end of the stud and jam 2 lug nuts on the long end and then screw it into the hub. The studs extend 1.25" after installation.
rvb is offline   Reply With Quote
Old 11-19-2014, 06:55 PM   #3
1975 25' Tradewind
Biddeford , Maine
Just ordered the studs. Thanks for the reply.
Old 11-20-2014, 07:20 AM   #4
You would be much better off if you replaced the drums.
Older style drums typically are way out out balance, since they are 2 or 3 piece. New style is one piece machined.
Keeping the running gear in proper balance, can be a real issue, if ignored.
Old 11-21-2014, 07:13 AM   #5
1975 25' Tradewind
Biddeford , Maine
Good idea. Any recommendations as to where I should buy them?
Old 11-21-2014, 08:06 AM   #6
Airstream parts stocking dealers would have them, but also they can be drop shipped to you to save on freight.
Airstream parts from a non-Airstream dealer, do not carry the factories warranty, as per Airstream.
Old 11-22-2014, 09:14 AM   #7
1975 25' Tradewind
Biddeford , Maine
HA! The trailer is 40 years old. I'm not too concerned about a warranty at this point
Old 11-22-2014, 09:23 AM   #8
Not on the trailer, but on everyday parts.
All Airstream parts sold through an Airstream dealer, carry a warranty of some kind.
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 08:51 AM
Hub Bolts to Nuts? Roadrunner Wheels, Hubs & Bearings 1 11-03-2012 08:32 PM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts dorfgog Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
Why should I convert my bolts to studs and nuts? lebolewis Wheels, Hubs & Bearings 22 05-04-2007 10:33 AM
