Old 06-06-2013, 11:03 PM   #1
1986 29' Sovereign
Chanhassen , Minnesota
Chrome Wheel Bolts - Purchase where?
Where can you purchase new chrome bolts?
Harrysheets is offline   Reply With Quote
Old 06-06-2013, 11:23 PM   #2
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
If you mean 'lug nuts' that bolt your wheel to your vehicle's wheels you can find those at any auto supply and tire store.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-07-2013, 05:15 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I got ours from Amazon, make sure of the size.
You won't find any better quality.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-07-2013, 08:46 AM   #4
1986 29' Sovereign
My trailer has Bolts with a tapered head which threads into the axle. I could replace the bolts by loctiting in studs and making it more like a typical car / truck (thus using nuts). I was however tying to find a nice chromed bolt similar to the zinc bolts offered by Inland RV.
http://www.inlandrv.com/catalog/images/11330.jpg
So far I have only found a couple companies selling the same zinc bolt.
Harry
Old 06-07-2013, 08:58 AM   #5
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Harry
My 1976 31' Sovereign had "lug bolts" just as you describe and were covered by hubcaps. When I decided to change over to 16" wheels and tires I went with aluminum wheels and tried to find the chrome lug bolts. They are not available. So I used lug studs and then was bale to use the standard chrome lug nuts. I eventually replaced the axles which came equipped with standard lugs.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 06-07-2013, 09:29 AM   #6
Thumbs up
Give them a call for sizing...
PFC
"Tahawus"
RLC
John Prine
Old 06-07-2013, 10:46 AM   #7
adonh's Avatar
1976 31' Sovereign
I stand corrected.
Don Hardman
1976 31' Sovereign
Old 06-07-2013, 11:30 AM   #8
1986 29' Sovereign
I called this company as a they appear to make a nice bolt lug. The only problem they only offer metric, nothing in a 1/2 - 20
Old 06-07-2013, 03:12 PM   #9
adonh's Avatar
1976 31' Sovereign
That's to bad, those looked good. The studs will work and I found them online but its been a long time and I can't find the source. I used lock tight red on the ends that go in the hub. and then was able to use regular chrome lug nuts with my aluminum wheels. They worked fine for me. But do your own research if you go this route to make sure that it will work for your set up.
Don Hardman
1976 31' Sovereign
Old 08-26-2013, 04:42 PM   #10
Phil&Sher's Avatar
2008 25' Safari FB SE
Central , Florida
Thanks for the recommendation Bob. I just received 24 of these 1/2-20 McGuard #64010 premium nuts from Amazon today and the quality of these made in the USA lug nuts is top-notch.
I tried one for fit and, despite most dimemsions measuring the same, visually the McGuard seems to seat just a bit further into the wheel hole when torqued to the same value. The only two differences I could find between the OEM and the McGuard was the McGuard nut is threaded about 2mm more shallow than the OEM (total inside depth virtually identical), which wouldn't account for it.
But while the cones are very similar in diameter (+/-.5mm), the metal cover over the OEM lug nut is 3mm wider overall just above the cone ....and the cover shows asymmetrical wear signs (the cover is crooked on the nut). Which says to me that the OEM doesn't fit the wheel hole pocket quite as well as the McGuard. Thus, I may have been drawing up the nuts (at least those that are bulged) partially against the bottom skirt of the cover instead of fully against the cone itself. Maybe that's why the covers are split and bulging on some of my OEM lug nuts. I think I'll feel safer with the McGuards
Phil
Phil&Sher is offline   Reply With Quote
Old 08-26-2013, 04:58 PM   #11
1977 Argosy 24
Milltown , Wisconsin
When I converted my Argosy from lug bolts to studs and lug nuts, I bought solid lug nuts not the ones with the chrome covers. They work much better.
ventport is offline   Reply With Quote
Old 08-26-2013, 05:03 PM   #12
Thumbs up
Your welcome Phil
Have to support local bussiness'....made right here in Western NY.
PFC
"Tahawus"
RLC
John Prine
Old 08-27-2013, 05:29 AM   #13
Phil&Sher's Avatar
Central , Florida
Your welcome Phil
I used to spend 100 nights per year in Rochester and 10 or 20 in Buffalo, when I was working. Western New York is beautiful country. Looks like McGuard is helping to contribute to both a growing population and low unemployment up there, too
Old 05-30-2014, 05:53 AM   #14
1970 25' Caravanner
Dassel , Minnesota
I picked mine up from Amazon. Gorilla lugs. Search gorilla site for phone # and call them. Great costumer service, get the size from them then order from amazon. Mine were 1/2 20 bulge head closed lugs and priced at 43$ or so for a set of 24. These were key type and come with key socket. Very nice set.
5ndime is offline   Reply With Quote
