Old 07-08-2014, 03:47 PM   #1
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Changing wheels on a 2006 23 foot Safari
OK, have read this entire thread at least twice hoping to come across info to upgrade the wheels/tires on the 2006 23 foot Safari (double axels). Based upon what has been publish so far, I have discerned that all AS's with double axels, no matter it's over all length, have the same wheel well dimensions. Also that 14, 15, and 16 inch rims (with zero off-set) will bolt up to the axels with no clearance issues. Now I have stock 14 inch rims with 215/75-R14 Towmax tires and would like to upgrade to 15 or 16 inch rims, but notice that going to a 16 inch rims maybe out of the question due to have a 5 lug bolt pattern. I find that the Michelin LTX M/S would be fine for me, but also find that going to a 16 inch rim, I would have to go to a 235/75-R15 (16). So is there a 16 inch replacement rim for 5 lug hub and will there be clearance issues going to a 235 tire. Looking for input to my question so I can get the change over done before I hit the road for a couple long distance trip later this year. Thanks in advance for your assistance.
tsunami is offline   Reply With Quote
Old 07-08-2014, 05:17 PM   #2
2007 23' Safari SE
2016 23' International
Fernandina Beach , Florida
I've followed this whole wheel upgrade debate for some time now without commenting. The forums are great for learning about anecdotal data based on real world experiences, but I tend to believe the squeaky wheel gets the grease and complainers tend to dominate the boards. That is to say things aren't all as bad as they are made out to be. Case in point GYMs and 14 inch wheels.
Have been perfectly satisfied with both, but would not consider upgrading wheels...Do they make the trailer roll any better? Thats debatable. Marginally higher, yes, better? And as you have pointed out the wheel wells are about the same and if the blowout rate is roughly the same for tires of different size (independent of the whole brand and type, ST or LT,debate), wouldn't larger tires cause more damage to the well and the surrounding trim and skin?
I believe proper tire maintenance is the key and as such, as I am planning a major cross country trek, I just replaced my GYMs (I'd rather not get into the debate on what brand). I will say the new tires are not GYMs but I will also say the GYMs have been trouble free for me.
For me, I chose to have that work done by Discount (Americas tire), and they did a great job. I like the free rotation and balancing and yes I did buy the road hazard coverage so blowouts are less of a concern. I wanted a tire that was readily available and an installer that has a great distribution network. Perfectly happy to stick with my 14's. Next job up is having the bearings repacked and and brake inspection and we'll be ready to roll. New tires all around on the TV as well.
I guess if I had an issue with an axle, I'd consider upgrading to the neverlubes and may as well go with 15 inch rims at that point, but I'll cross that bridge when I get to it. Not one to spend lots of extra for marginal gains.
Tomzstream is offline   Reply With Quote
2006- 20 foot Airstream Safari Travel Trailer eBay Watch Airstreams on eBay 0 11-23-2012 01:30 PM
2006 Airstream Safari 28 foot 75th Anniversary Edition eBay Watch Airstreams on eBay 0 05-30-2010 08:00 PM
A two foot scratch to my 2006 Safari - nooooo! 10acKen Ribs, Skins & Rivets 13 08-17-2006 11:13 AM
