Old 06-07-2012, 02:27 PM   #15
Originally Posted by SilverGate View Post
Will be replacing our original Marathon tires this summer before resuming our camping in the fall and would like to install the Centramatic wheel balancers at the same time.
Can anyone confirm the correct Centramatic model/part number for our 23' 2007 Safari with 14"x6" aluminum wheels with 5 lug holes?
Which Centramatic you "might" be able to use, is a function of the wheel design.
Typically mag or aluminum wheels are "cone" shaped on the backside. That then interfers with the Centramatic flat plate.
Measure the backside of the wheel to see how large a flat area is, where a flat "dish" wwould seat.
Typically, a minimum of a 9 inch flat dish area is necessary, so that the balancer is not damaged.
Old 06-09-2012, 12:31 PM   #16
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Updated part #'s for Centramatic wheel balancers
Yesterday, Jerry of Centramatic confirmed the correct part number for Airstream trailers with 14" wheels, 5 lug holes and a bolt circle of 4.5" is 200-221.
He also emailed me this additional information:
THE 200-221 SPECIALS 12 Ύ” OD PLATE ARE FOR 6 STUD 15”RIMS
THE 200-221 WHICH IS A 10” OD PLATE
HERE IS THEY WAY IT GOES FOR AIRSTREAM TRAILERS
WITH STOCK RIMS AND AXLES:
14” – 15” RIMS 5 LUG 4.5”BC 200-221
15” RIM 5.5” BC 6 STUD 200-221SPECIAL
16” RIM 5.5” BC 6 STUD 300-356
16” RIM 6.5” BC 8 STUD 300-318
Originally Posted by BDandTTs View Post
We've received the Centramatics but are waiting for the new tires. We'll post an update quickly after install.
Dianne, looks like you were about to install Centramatic wheel balancers #200-221 in the fall of 2010. A number of us would appreciate hearing how your install went and have you noticed benefits since then (such as fewer rivets popping or more even tire wear).
It looks like these balancers would be especially beneficial for those of us who attach tire pressure sensors to our tires.
Thanks to all who have contributed information here!
Name:	DSC_0123 14" Tires.jpg
SilverGate is offline   Reply With Quote
Old 06-09-2012, 12:44 PM   #17
Jerry, unfortunately, all too many times, assumes that the back of all wheels are flat.
Mag wheels in particular, are cone shaped on the back side and therefore no Centramatic balancer will proper fit.
We have gone through this many times with owners.
Before anyone orders the Centramatic balancers, that are using mag wheels, measure the absolute flat area on the back side of the wheel.
If it does not measure at least 9 inches, then Centramatic does not have a balancer that will fit properly.
The 200-221 specials are made for us, and Jerry keeps forgetting that fact.
Old 06-09-2012, 01:15 PM   #18
SilverGate's Avatar
2007 23' Safari SE
In fairness to Jerry, when he saw my photo, he said in the first part of his email to me:
"ARE THESE RIMS ORIGINAL RIMS?
IF THEY ARE AFTERMARKET WE MAY OR MAY NOT FIT DUE TO THE INSIDE SHAPE OF THE RIM"
... and of course my 14" rims are the original rims that came with my newly built 2007 23' Safari.
Old 06-10-2012, 10:06 PM   #19
The question is still, "does the back side of the wheel have a 9 inch flat circle or more" ?
I certainly have no idea what wheel Airstream installed on your coach.
Old 06-11-2012, 09:27 AM   #20
SilverGate's Avatar
2007 23' Safari SE
My wheel pictured in post #16 above and in photo below is the OEM 14" styled aluminum wheel with 5 lug holes placed on my brand new at the time 2007 Safari.
I have contacted numerous people privately here on the forums and read the other Centramatic threads and I am amazed that I can find no one who has 14" wheels with the same style as mine who actually uses the Centramatics...
I'll probably wind up replacing the Marathons and have them balanced with the Pressure Pro senors in place and forgo what looks like unnecessary expenditure for me and the possibility that they won't fit properly anyway.
Name:	DSC_0125 My 14" OEM 2007 wheel.jpg
Old 06-11-2012, 10:06 AM   #21
Only you, have the answer to your own question.
Take one wheel off and measure the backside of the wheel for a 9 inch flat spot.
No one else can do that but you.
Once you have that info, then you can go to the next step.
It's a huge waste of time, asking Airstream what wheels they installed on your trailer, and what does the backside look like.
Old 06-12-2012, 08:45 AM   #22
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
Centramatics
Silvergate,
He is my rims on my AS. Looks the same as yours. the centramatics fit well behind the rim.
Sorry I can't find a pic of the centramatics on the hub.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 06-12-2012, 09:01 AM   #23
SilverGate's Avatar
2007 23' Safari SE
Originally Posted by Sphere Guy View Post
Silvergate,
Thanks Sphere Guy... Yes the rims look like the same style as mine... Just to be sure, are your Centramatics on the original 14" wheels or are these on larger wheels?
Old 06-12-2012, 09:03 AM   #24
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
They are on the original 14" wheels. I'll get a pic this afternoon and send to you. I also have a pic of the inner side of the wheel and I think a measurement. I'll look for them.
Sphere Guy
AIR 50601
Old 06-12-2012, 09:07 AM   #25
SilverGate's Avatar
2007 23' Safari SE
Thanks for this additional information... Looking forward to the pic!
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 53 01-23-2011 06:41 AM
Wheels for "78" Ambassador Roadrunner Wheels, Hubs & Bearings 2 03-12-2010 04:06 PM
Centramatics -- 16" wheel rim size larry b Wheels, Hubs & Bearings 14 01-26-2010 04:38 PM
15" Aluminum rims & Centramatics davidz71 Wheels, Hubs & Bearings 22 01-10-2010 01:57 PM
Correct Wheels "78" Ambassador Roadrunner Wheels, Hubs & Bearings 2 09-21-2009 03:14 PM
