Old 09-19-2013, 08:21 AM   #1
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
Centramatics - cost worthwhile?
Is the expense to have Centramatics installed worth it? Do they really cut down on vibration and lengthen the life of the tires?
kswelsh is offline   Reply With Quote
Old 09-19-2013, 08:35 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I use Centramatic wheel balancers on both of my Honda Gold Wing motorcycles in lieu of wheel weights and they work well. I put them on the 25FB with 15" OEM wheels and Michelin tires properly balanced and have a larger set for the new 16" wheels and Michelin tires for the new trailer on order.
They might not be necessary for disk brakes, but will install them anyways.
Old 09-19-2013, 09:15 AM   #3
There's nothing tough about installing Centramatics.
You remove the wheel, plsce the Centramatics over the studs, and then reinstall the wheel. DONE.
Centramatics are useful in every situation.
Using disc brakes, still requires balancing of the wheels and tires.
Best of all, no more searching for a shop that can balance the tire, wheel, hub and drum as an assembly, or even the tire, wheel and rotor as an assembly, as the case may be.
Old 09-19-2013, 10:19 AM   #4
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
It is hard to answer that question empirically because one would have to have the exact same experiences both with and without them. However, to me, common sense dictates that they will have a positive affect on both tire life and vibration. How much affect is hard to state with certainty and depends in each case on many variables.
I have my trailer tires and wheels balanced every 5000 miles. However, partially because the tire weights are there, I use Centramatics. I feel it refines the balance and maintains the balance if a tire weight is lost or you pick up a bunch of tar in the tread, etc. Centramatics will adjust to changes. Tire weights won't.
Like my TPMS, I consider then to be "peace of mind" equipment. (one less thing to worry about)
Ken
Old 10-14-2015, 05:57 PM   #5
1964 19' Globetrotter
Collierville , Tennessee
Andy:
You have helped me with some good advice on replacing the axle on my '64 GlobeTrotter. I am ready to upgrade the wheels from the original split rims to new conventional rims. The issue is that I want to use my original hub caps from the split rim wheels that do not use clips but are secured against four studs on the rim. Do you know of a wheel I can buy that matches what I believe are the original hub caps? Thanks!
Craig
Boneydog1225 is offline   Reply With Quote
Centramatics for Vintage? TomW Tires 49 04-25-2010 04:37 AM
Worthwhile Up-grade ROBERT CROSS Tow Vehicles 6 09-03-2007 07:50 PM
Worthwhile upgrading Dual-cam? SafeHarbor Hitches, Couplers & Balls 8 06-18-2006 06:29 AM
Centramatics, split purchase Zeppelinium Wheels, Hubs & Bearings 6 05-18-2006 10:27 AM
