Old 03-28-2013, 11:33 AM   #1
gtc6452's Avatar
2015 27' Flying Cloud
2011 30' International
mooresburg , Tennessee
centramatics and nev-R-lube bearings
just read in the Blue Beret that you should not use the Centramatic Wheel balancers with the Nev-R-lube bearings, what has anyone heard?
gtc6452 is offline   Reply With Quote
Old 03-28-2013, 11:38 AM   #2
dznf0g's Avatar
Oswego , Illinois
Their contention is that it offsets the load by about 1mm, creating a potential uneven loading of the bearings. The same theory holds for all bearing setups, not just Nev-r-lubes. In theory they are correct......in practice....I have heard of no issues. I will continue to use my centramatics with my Nev-r-lubes, as I have on some vehicles in the past.
-Rich-
Old 03-28-2013, 12:02 PM   #3
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
This is what I love about the internet no matter what you think you know you don't. On RV.net they were talking about Michelin tires and blow outs,they were talking about class A units and bigger tires here Michelin LT tires are the go to tire. I am going to keep my just installed centramatics, not rolled one revolution yet, on my trailer along with the Goodyear tires it came with. I will watch those tires like a hawk, I do believe the can have issues the Centramatics not so much.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 03-28-2013, 02:16 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Ain't it the truth?
Originally Posted by Jim Clark View Post
This is what I love about the internet no matter what you think you know you don't. ...
Yes, and it's all true!
Bon jour,
Tom
Old 03-29-2013, 04:26 AM   #5
gtc6452's Avatar
this is coming from someone at airstream.
Old 04-09-2013, 05:36 AM   #6
Arrowstream's Avatar
Columbia , South Carolina
What dznf0g said... the Nev-r-lubes require a zero offset. Dexter has that specified in their product description.
" Use only zero offset wheels on these axles"
Arrowstream is offline   Reply With Quote
Old 04-09-2013, 06:32 AM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I would call it sadomasochistic equine necrophilia,
but that is beating a dead horse.
I will continue to travel with with my Centramatics installed.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 04-09-2013, 07:15 AM   #8
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
Keep wheels balanced by having them load-test balanced when they're serviced and you have your cake and eat it, too: Nev-R-Lube-bearings and balanced wheels.
JBinKC is offline   Reply With Quote
Old 04-09-2013, 08:13 AM   #9
dznf0g's Avatar
Oswego , Illinois
But that does nothing for the notoriously unbalanced hub and rotor/drums.
-Rich-
Old 08-08-2013, 10:51 PM   #10
daveswenson's Avatar
Issaquah , Washington
I had a long talk with Jerry Robertson, Director of Tech Support at Centramatic, today. He was very familiar with the Schu's article in the Blue Beret and has been in touch with both Schu and the engineers at Dexter. He threw a lot of info at me but Ill try to summarize. In trying to pin Dexter down they admitted that it would take 1/4 to 1/2 inch of offset to cause bearing problems. Since the Centramatic is only about 20/1000ths thick,it shouldn't be a problem, but since Dexter had not tested the Centramatic they could not endorse it. He tried to get Airstream to print a clarification. They refused, saying since Dexter wouldn't give an OK they couldn't either.
Sounds like a lot of CYA. I'll be ordering mine.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-09-2013, 08:10 AM   #11
dznf0g's Avatar
Oswego , Illinois
Dave, this is exactly what my experience tells me. However, I do think that as little as 5 - 10mm of offset could reduce bearing life, so I am a little taken a'back at the 1/4 to 1/2" statement.
-Rich-
Old 08-09-2013, 08:26 AM   #12
In retrospect I think the 1/4 to 1/2" figure was when it would get critical. Jerry is a Texan so he talked a lot. And since 10 mm is about 3/8 inch the numbers aren't that far off.
I think that the 5/1000" that Jerry claimed is the Centramatic offset would be well within what you could expect to experience just from tire or wheel variations. If Dexter is expecting those tight of tolerances in the real world then we all are going to have problems, Centramatics or not.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
Old 08-09-2013, 09:18 AM   #13
Dexter makes many claims that I think are from the "real old school".
They say no shocks needed, but Airstream makes them do it.
Dexter has drawing for the shock brackets, that we have, but they say it's a waste of money.
Personally, I think the scare tactics is about worn out.
If the never lube is that critical, then what happens when several ounces of weight is added to the wheel to balance it?
I really think the saga is in it's last chapter, since the Dexter old timers are about aged out.
Technology advances, in spite of some people.
There are many things today that just a few years ago were said to be impossible.
I love my "impossible" 12 volt portable little refrigerator that works off of 12 volts DC. No compressor, but keeps things at 40 degrees. No ice, no water, no mess. Then if you wish, reverse the polarity and the frig becomes a warmer, keeping things at 140 degrees.
The small frig holds a little more than 12 12 ounce cans.
Even comes with an AC adapter so that you pre cool or pre warm it in your home.
Fanastic to travel with.
Target was selling them for $ 29.95.
Old 08-09-2013, 09:20 AM   #14
2006 30' Classic
Milton , Florida
Centramatics on 30 ft. Classic
I have been running Centramatics on our 2006 30 ft. Classic for about three years and a little over 25,000 miles with no indication of problems to date.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
