02-24-2010, 05:11 PM
#41
2005 25' International CCD
Fleetwood
, North Carolina
Originally Posted by ROBERT CROSS
Lynn,
You do realize that the British SAE has just recently determined that oil is a liquid and the Lucas electrical system actually requires electricity to operate properly.
Yes, this despite the oil always pouring from engine to pavement.
I don't think their finding on "needing electricity" was likely to be helpful -- our Lucas electricals worked 'bout the same with and without electricity .
02-24-2010, 05:30 PM
#42
2005 22' Safari
Gresham
, Oregon
Centramatics
It's pretty easy to get a photo of the outside of the wheel, but getting a meaningful photo of the underside is tougher without removing the wheel. Too much to get done on the lunch hour. I'll try to send photos of the wheel that may help.
2005 22 ft Safari LS
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
02-24-2010, 06:52 PM
#43
Airstream - Other
Bosque Farms
, New Mexico
Oh, you just don't understand! That oil leaking is not leaking oil. That's built-in rust prevention.
Lynn
ACI Big Red Number 21043
02-24-2010, 07:36 PM
#44
_
Originally Posted by rustyrivet
...getting a meaningful photo of the underside is tougher without removing the wheel...
rusty...
the wheels on your trailer have zero offset.
generally the ruler along the back side is to determine the space available when the offset is negative.
there should be NO problem fitting the centra discs in your case.
these guys having issues are rolling on old steel rims, that are spaced differently than modern alloy trailer rims.
a call to the centra' factory with your rim diameter and the info "zero offset" will get the right size.
and u won't have to bend/mold/compress or otherwise mash them.
while bob's trailer has 15s u can get a CLEAR picture of how they fit in post #61 here...
http://www.airforums.com/forums/f438...ate-32907.html
just let 'em know IF u have 14s...
cheers
2air'
02-24-2010, 08:00 PM
#45
Vintage Kin
Fort Worth
Put a set of the 300-308's (15") on mine. That, new shock absorbers and an axle alignment (beam axle) made a world of difference on our S/S with it's wooden wagon suspension.
02-24-2010, 09:01 PM
#46
2005 22' Safari
Gresham
, Oregon
Thanks, 2air. I will give them a call this week and see what they come up with. jc
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
02-25-2010, 10:42 PM
#47
Corona
Centramatics
A suggestion to those that have asked questions about Centramatics.
The "KEY" is the absolute flat dimension, on the inside of the wheel.
As an example, the inside of a 15 inch wheel, is not a flat clear 15 inches.
That dimension dictates which model will properly fit.
Regarding aluminum wheels. The inside wheel dimension is usually different than for the same size steel wheel.
02-26-2010, 05:58 AM
#48
2004 30' Classic Slideout
2021 33FB Classic
Colleyville
, TX
Great product! We've been using them for five years or more and from all indications i.e. tire wear & tightness of our coach interior, they do a marvelous job. Like a good hitch setup, proper tire inflation and towing speed they provide peace of mind.
In dog years, I'm dead!
03-09-2010, 12:07 PM
#49
2005 22' Safari
Gresham
, Oregon
I finally spoke to Jerry (the Airstream expert)at Centramatics. He wanted me to read all the numbers off his tire to make sure he was truly dealing with a 14" tire set up. After I gave him all the numbers off the tire, he was uncertain that there was enough inside clearance for the centramatics to fit. Apparently the 14" wheel (aluminum) are a bit rate. Perhaps I should just order a set and see if they fit properly. If not, I guess I can pay the freight to send them back. jc
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
03-27-2010, 09:23 PM
#50
2005 22' Safari
Gresham
, Oregon
OK, I got the Centramatics and installed them on the hubs. They fit fine on 14" wheels as long as the tube for the bearings was turned out (toward the wheel and not in toward the hub). I expect that they will keep everything in balance. Next project; install the tire pressure monitor system. jc
2009 Toyota Tundra
Hensley Hitch
Lifeline AGM's
05-31-2010, 02:47 PM
#51
2006 19' Safari SE
Tucson
We ordered a set from Andy at Inland last week! Can't wait to get them on and take a trip! Thanks for your help, Andy!
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
05-31-2010, 02:50 PM
#52
2011 25' FB Flying Cloud
Anywhere &
, Everywhere
How about posting the stock # of your 14" Centramatics.
05-31-2010, 05:41 PM
#53
Corona
According to our information, that should be a part # 200-221.
They are 9 7/8 inches in diameter.
