Old 10-16-2013, 07:11 AM   #1
1988 25' Excella
Trumbull , Connecticut
Centramatics?
Hello fellow Streamers. Looking for info on centramatic balancers. I have 16" sendal alum wheels and I was wondering if I installed centramatic balancers, how far they would move the wheel outboard. I have a 25' 1988 Excella and there doesn't seem to be a lot of extra room before the tire rubs on the outer edge of wheel well.
Anyone done this?
Thanks nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 10-16-2013, 07:14 AM   #2
dznf0g's Avatar
Oswego , Illinois
Roughly .030"...just the thickness of the metal plate which is sandwiched between the wheel and hub face. A non-issue, IMO.
-Rich-
Old 10-16-2013, 07:19 AM   #3
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
There are several very good threads available in the search section that will answer just about any question you may have on mounting realizing the benefits of Centramatics. I don't recall any that talked about fit issues. Make sure you call the Centramatics folks and they can make sure you get exactly the right product for your application--they are very experienced in fitting Airstreams.
wolverine is offline   Reply With Quote
Old 10-16-2013, 07:24 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
X2
.030 no problem...
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-16-2013, 07:30 AM   #5
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I have the Sendel T03 16" wheels and there is no issue with fit. As previously noted the disk is about 0.030" thick, maybe the thickness of about 15 magazine pages.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 10-16-2013, 07:32 AM   #6
dznf0g's Avatar
Oswego , Illinois
...Or a matchbook cover....remember emergency setting of distributor points?.......(that's for you older guys)
-Rich-
Old 10-16-2013, 07:58 AM   #7
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Ha, that's funny! It worked on my 62 Dodge Dart and 61 T100C. Sorry, off topic.
DryFly is offline   Reply With Quote
Old 10-16-2013, 03:48 PM   #8
1988 25' Excella
Just want to thank all who responded. I thought the disc was a 1/4" or so in thickness. It really is a non issue
Thanks nm1oqrz
Old 01-22-2014, 08:55 AM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I think they are saying to remove then and see if there is a change....ie. eliminate them as a possibility. The only real failure mode of a centramatic is loss of it's oil. Then, I suppose, over time, the balls could stick or wear the tube....but I doubt they are your issue.
Has anyone ever had a failure of a Centramatic?
Alan
Old 01-22-2014, 09:03 AM   #10
dznf0g's Avatar
Oswego , Illinois
I have not, but I recall a discussion where there was a small population with a sealing issue and allowed for all the fluid to escape. This thread was a couple years ago, I recall only one member with the issue, and Centramatic stepped up as I recall.
-Rich-
Old 01-22-2014, 07:42 PM   #11
2008 27' Classic FB
Burkburnett , Texas
When removed you should be able to determine if they have leaked or are damaged in some way. The device is a disk with a sealed metal tube around the edge. The tube contains a number of balls roughly the inner diameter of the tube and an oily fluid. As you slowly rotate the disk you should hear the balls moving to the bottom. The fluid will dampen the motion and the sound but you should be able to determine that the balls move. If the tube got dented, the balls wouldn't be able to circulate freely or as mentioned it is possible the fluid leaked out. Aside from such damage these things are pretty foolproof.
AIR 47751
Old 01-23-2014, 03:23 AM   #12
Luigi123's Avatar
2018 30' International
2014 30' Flying Cloud
Los alamos , New Mexico
Andy, do you recommend the Centramatics-- my new AS 30ftFC arrives this next month of February, clueless on the application of this product.
Luigi123 is offline   Reply With Quote
Old 01-23-2014, 05:37 AM   #13
Absolutely.
Last year, we processed over 400 sets.
Balancing tires, is a never ending job, as it's supposed to be done every 10,000 miles or so.
I have never found a balanced tire, to still be in balance at 10,000 miles.
So the question becomes "exactly when" should it have been rebalanced.
Who knows????
Once the Centramatics are installed, that worry is forever over, as the Centramatics keep the running gear in balance as soon as they hit 25 mph or close to it.
The exceptions would be using them on the old 3 piece hub and drums, or if the wheel was bent oor damage to the tire.
Other than that, they work very well.
Just something an owner won't need to watch any more.
Old 01-23-2014, 08:02 AM   #14
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
After installation of the Centramatic balancers is it still necessary to do the traditional dynamic balance of the wheel / tire combination ????
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
