08-07-2013, 04:58 PM
2008 25' Safari FB SE
Victoria
, BC
Centramatics
Hi all,
I am considering the purchase of Centramatics to go on with my new 16" Sendel T02 rims. I expected to be ordering the 200-221 Special version of these.
When I emailed Centramatics about shipping, I also mentioned what I was going to be doing with the new wheels & they recommended a different Centramatic model number.
From them:
'GOOD DAY
YOU CAN USE A SET OF 300-356 MUST SPECIFY WITH ALL "A" PLATES FOR 16"RIMS'
For those of you more familiar with the Centramatics, what do you think of this recommendation?
Thank you for any advice.
- evan
08-07-2013, 06:05 PM
Oswego
Hmmmm, I'm certain I have the 200-221 Specials with my Sendel T02s.
Call them and clarify.
-Rich-
08-07-2013, 06:21 PM
Salem
, Oregon
Originally Posted by eheffa
Hi all,
From them:
'GOOD DAY
- evan
Hi, those are the ones that I have [10"] but they also have 12" ones that I would rather have had. I think they list the 12" ones as for fitting a Jeep.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
08-07-2013, 06:24 PM
Victoria
, BC
Thanks Robert.
Why 12"? Do they work better with a larger diameter ( more mechanical advantage)?
- evan
08-07-2013, 06:25 PM
Victoria
, BC
Thanx.
I have emailed them for clarification but thought I would post that question here.
- evan
08-07-2013, 06:32 PM
1960 24' Tradewind
Riverside
, United States
The 300-356 will fit a 16" wheel as will the 200-221AS, but the 300-356 will not fit a 15" wheel.
Greg
Greg Paulsen
08-07-2013, 06:39 PM
Oswego
Ah, that answers it. I had my Centramatics when I had my 15" wheels...forgot about that.
-Rich-
08-08-2013, 09:59 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Aistream Centramatic device on Backorder
I called Centramatics today (8 August 2013) to check out my back order status for the "200-221 Special" used only on Airstreams and it may be into September before they ship those units out.
YMMV
08-08-2013, 10:32 PM
Victoria
, BC
YMMV
Centramatics told me that with 16 inch rims you can use the larger version:
From Jerry: YOU CAN USE A SET OF 300-356 MUST SPECIFY WITH ALL "A" PLATES FOR 16"RIMS
- evan
08-09-2013, 01:32 AM
2005 19' Safari
GLENDALE
, AZ
We first installed our Centramatics when our 2005 Bambi still had the 15-inch OEM wheels, and they fit the 16-inch Sendel T02's when we switched. With balanced Michelin LT tires, I'm not worried about the "Airstream special" Centramatics not being large enough to balance the running gear.
Just my opinion, but if I had to decide again, I'd buy the same Centramatics from Andy a second time and not worry any more about it.
08-09-2013, 07:06 AM
1969 29' Ambassador
brooksville
My centeralmsatics are still sitting on the shelf waiting to be installed. What side goes against the drum? Or should I say what side does the raise bead go on. The rim side or the drum side?
08-09-2013, 07:27 AM
Oswego
The ones for 15" wheels will still be effective with 16" wheels. IIRC, Centramatic states that their products start to perform their auto-balancing at about 30-35 mph. So if a Centramatic made for a 15" wheel is used on a 16" wheel, the RPMs of that wheel will be less than the 15" wheel at a given road speed. So a 220-221 will just start it's effectiveness at a slightly higher road speed.
-Rich-
08-09-2013, 07:28 AM
1985 31' Excella
Seguin
Raised bead toward the drum on mine.
08-09-2013, 07:31 AM
Oswego
Drum/rotor side.
-Rich-
08-09-2013, 02:30 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
This thread reminded me that I've been meaning to get some.
I ordered mine today. Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
08-09-2013, 02:54 PM
2014 31' Classic
Apache Junction
Just called Centramatics, Friday, 9 August, and the 300-356 with all A plates for 16" wheels is now on back order along with the 200-221 Special units.
08-09-2013, 03:07 PM
2012 28' International
Olympia
So apparently the Blue Beret article hasn't hurt sales.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
08-09-2013, 06:59 PM
2014 31' Classic
Apache Junction
To clarify Centramatics part numbers as they apply to Airstream use on 15" and 16" six lug wheels with 5.5" bolt circle.
The 200-221 Special can be used on both 15" factory wheels and the 16" Sendel wheels.
The 300-331 can be ONLY on 16" wheels and some folks have ordered them for SenDel wheels.
As of this afternoon, 9 August, both models are on backorder. There was no clarification if this is from great sales or of a manufacturing or raw materials supply problem.
08-10-2013, 07:34 AM
2002 30' Classic S/O
Garden Valley
, Idaho
According to the tech specialist at Centramatics, it doesn't make any difference as to bead in or bead out as long as it fits. I did bead in on my AS and bead out on my TV. All seem to be working perfectly.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
08-10-2013, 07:41 AM
Oswego
True, check fit. IIRC both the original AS 15" wheels and the Sendel T02s would not allow clearance for "bead ring" to the outside.
-Rich-
