Old 07-29-2010, 01:27 PM   #1
2006 30' Classic
Milton , Florida
Centramatic Wheel Balancing Installation
I installed the Centramatic wheel balancing assemblies on my 2006 model year classic. All that is required is to remove the wheel, place the Centramatic assembly over the lug studs, and reinstall the wheel on the axel. Technical details are:
Model year: 2006 Classic
Length: 30 feet
Rims: 15x6 six lug aluminum wheels as supplied by Airstream (5.5 inch dia. bolt circle)
Axels: Dexter
Brakes: Dexter hydraulic disc brakes
Centramatic part number: 200221SPECIAL (The word SPECIAL is important in the part number)
Centramatic contact: Jerry Robertson
We have not yet used the trailer since the installation. Now for a question. How am I going to tell if the Centramatic balancing assemblies have improved the ride? Can someone suggest what to look for?
Nick Meloy
07/29/2010
nickmeloy is offline   Reply With Quote
Old 07-29-2010, 01:35 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
In my case, I noticed the placemats on the dinette table rarely moved around. I also noticed a bit less movement of items within the RV. I'm not sure how much improvement they deliver, but I firmly believe that there is some benefit as truckers usually don't waste money on snake oil type gimmicks and many truckers use these. Anything to soften the ride is a good thing IMHO. Eventually I may also get an air hitch too.
Old 07-29-2010, 01:38 PM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I have put Centramatics on a pickup truck and a set of balancing beads in another vehicle. Both had similar effects - less vibration at cruising speeds above 55 mph.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 07-29-2010, 01:47 PM   #4
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
I found that stuff accidentally left on the counter would be there upon arrival. That never happened before the Centramatics.
I have about 5 years use on 2 Airstreams and would not be without them.
John W. Irwin
WBCCI #9632
Old 07-30-2010, 06:27 AM   #5
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
We've used ours since '04 and after time one indicator might be in observing tire wear. The fact that I saw so many truckers at the manufacturing plant when I purchased ours was almost enough for me.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Correct Centramatic installation ? 63air Wheels, Hubs & Bearings 10 06-02-2009 10:16 PM
Wheel and Hub balancing adonh Wheels, Hubs & Bearings 7 04-07-2008 05:40 PM
Tire/wheel balancing Goin camping Tires 7 07-02-2007 11:29 AM
Centramatic Wheel Balances 53flyingcloud Axles 40 08-10-2004 04:01 PM
Running Gear Balancing - Centramatic vs Balancing Beads Austin Runner Wheels, Hubs & Bearings 0 03-14-2004 10:42 AM
