Old 12-17-2010, 03:26 AM   #15
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
As IRV pointed out getting complete hub assemblies balanced is all but impossible. I had access to a shop that could do it, however that shop is no longer in business.
I haven't had any experience with Dynabeads
Centramatics are good for the life of the trailer. . We use Centramatics on a fleet of trucks ranging from 1/2 ton up through 40 ton+ with great success. A new Airstream can cost upwards of $70,000, the cost of Centramatics is minuscule for the safety and quality ride they provide.
Aaron
WBCCI #XXXX AIR #2495
Old 12-17-2010, 05:37 AM   #16
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Originally Posted by nairnchyz View Post
You can get your tires balanced but your hubs will not be balanced and an out of balance hub can shake your trailer to pieces.
Hi nairnczyz;
With as much as I hate to sound controversial I must dispute your statement. All domestic made hubs are balanced. The proof of it is in welded small strips of steel onto the hubs. I have 12" brakes on my 26' Argosy. Before installing my new hubs we have placed them on crankshaft balancer and found out that differences were much too small to worry about at 12" diameter. Rims and tires are a different story being further from the center. Originally when building a new SS frame we installed shock mounts but decided not to install them on my new 3500lbs Dexter torsion axles. Even after near perfect balancing of the tires my trailer experienced vibrations which made things slide around inside for first 1000 miles. This test was done in order to find Merritt in statements made on the forums claiming that shock absorbers are not necessary on Airstreams. After installing new shocks everything stays in place even when driving on horrible pothole covered Pa, Rt 390. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 12-17-2010, 07:38 AM   #17
and my trusty lab Helga
handyman1425's Avatar
1972 29' Ambassador
1985 32' Excella
Cowiche , Washington
Parden me but i am new to the centramatic thing are yuall talking about putting spinners on your coach? What exactly are centramatics?
handyman1425 is offline   Reply With Quote
Old 12-17-2010, 07:39 AM   #18
Originally Posted by boatdoc View Post
Hi nairnczyz;
So much for the "no shocks needed" myth.
Our inspections of new style hub and drums, do not show any evidence of balancing. We further have tested all to many new style hub and drums, with our "Snap on balancer".
Regretfully, once again, no evidence of balancing has been found.
Our balancer, pictured in our web site, can balance to a very small fraction of an ounce. As a demonstraion, we show some customers that even the weight of a clean mens white hanky, placed off center at the top of the running gear assembly, is more than enough weight to make the assembly rotate.
Today, I will measure the weight of a like hanky, and post the results.
Old 12-17-2010, 08:52 AM   #19
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Ah, now, is that with or without the contents of the hanky?
Sorry, I just couldn't resist!
Lynn
WBCCI 21043
Old 12-17-2010, 09:03 AM   #20
dznf0g's Avatar
Oswego , Illinois
Centramatics (or the others) will help with load force balancing issues with tires as well. I suspect (no proof) that ST tires are not produced with the same attention to details such as load force imbalance as vehicle tires.
You will never get this issue addresses with the spin balancers at most shops.
Old 12-17-2010, 09:31 AM   #21
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Couldn't imagine running without our Hensley, Centramatics or Insurance of any kind for that matter.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 12-17-2010, 10:36 AM   #22
Lynn
As promised, we weighed a perfectly clean, mens white hanky, absolutely dry, AND no solids, at 12.8 grams which is .42 ounces.
A ST 225/75 R15 load range "D" tire weighs 30 pounds, the steel wheel weighs 25 pounds and the hub and drum weighs 40 pounds, for a total of 95 pounds.
Placing the "clean" mens hanky, slightly off center of that assembly, that's mounted in our Snap-on balancer, will make the assembly rotate since it's now been off balanced with less than 1/2 ounce of weight.
It's unfortuante that Snap-on tools, decided years ago to discountinue the manufacture of that balancer. It has worked for me, personally for over 40 years.
It's also very sad, that in spite of our "space age" accomplishments, that it's very rare to find a shop, that can balance a tire, wheel and hub and drum, as an assembly.
Anything that spins, must have some form of balancing, and the greater the weight as well as the greater the speed, makes that balancing even more important.
I wonder what would happen to a jet engine, revved up to flight RPM, if it was not very finely balanced? I would guess, that it would explode.
Old 12-17-2010, 10:47 AM   #23
boatdoc's Avatar
1973 Argosy 26
Lynn
I do not blame you Lynn. Lets get serious here. How much difference can a quarter ounce make at five inches radius from center of rotation when 2000 lbs is sitting on a tire? What about out of round tires even if they are perfectly balanced? Thanks, "Boatdoc"
Old 12-17-2010, 10:49 AM   #24
I do not blame you Lynn. Lets get serious here. How much difference can a quarter ounce make at five inches radius from center of rotation when 2000 lbs is sitting on a tire? Thanks, "Boatdoc"
All the difference in the world, as stated by several owners in their above posts.
Old 12-17-2010, 10:52 AM   #25
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Good test, Andy! I've been a believer for some time now with our old rims and bias-ply tires from China. Basically, I have the tires roughly balanced at the shop and then rely on the Centramatics to take care of the details, including the hubs and drums.
Lynn
WBCCI 21043
Old 12-17-2010, 10:54 AM   #26
dznf0g's Avatar
Oswego , Illinois
That's one of the components or possibilities of load force balancing, along with construction inconsistencies within the sidewall, not being seated exactly properly on the rim, etc.
Old 12-17-2010, 11:59 AM   #27
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I was a Snap-on dealer from 1977 until 1993. I agree with you Andy regarding those balancers. I used one to balance the flywheel in my VW powered dune buggy. They are a great tool.
The problem arose when the "automatic" balancers hit the market. They are far easier to use in that the operator doesn't have to do much thinking. They just mount the wheel, hit the green button and in a few seconds the machine tells them where to place weight and how much to place. For the most part, most of them work OK, and do save some time.
However, if you want to balance something other than a wheel and tire, they are useless. The old Snap-on balancer can be used to balance just about anything that can be mounted on it.
Hang on to yours.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 12-17-2010, 01:18 PM   #28
Hang on to yours.
I have 2 of them, you know "spares".
Centramatic Balancers Update... dscluchfc Tires 221 09-09-2016 10:08 PM
Correct Centramatic installation ? 63air Wheels, Hubs & Bearings 10 06-02-2009 10:16 PM
Centramatic balancers. Inland RV Center, In Commercial Listings 7 03-24-2009 02:53 PM
Centramatic alternative? bake315 Axles 7 11-18-2004 04:16 PM
Centramatic Wheel Balances 53flyingcloud Axles 40 08-10-2004 04:01 PM
