Old 07-13-2010, 05:05 PM   #1
2006 30' Classic
Milton , Florida
Centramatic Installations on 2006 Model Year Trailer
We have a 2006 model year 30' Classic with Dexter axels, Dexter hydraulic disc brakes, and aluminum rims with six lug nuts per wheel. Our unit was manufactured in late 2005.
I am considering the installation of the Centramatic wheel balancing system, and have two areas of concern. I would greatly appreciate hearing from owners that have completed such an installation on Airstream TT's having a similar setup.
I am concerned about the clearance between the outer tire sidewall and the fender well, and about the length of the wheel studs (Are they long enough?) after installing Centramatics.
Many thanks,
F. A. Meloy
nickmeloy is offline   Reply With Quote
Old 07-13-2010, 05:28 PM   #2
_
i've had them on a disc brake triple for ~50,000 miles.
the PLATE section of a centramatic is very thin, perhaps 2 mm at most.
so there should be NO impact on wheel well clearance or stud length.
after torquing the lugs several times (25, 50 and 100 miles) there is no evidence of lug/stud issues...
there are several threads on these balancing units with good pix and reports...
http://www.airforums.com/forums/f438...ate-32907.html
http://www.airforums.com/forums/f437...ces-10971.html
and several VENDORS now have photo documentation too.
there are some pix of the painted versions in posts #22 and 94 here...
http://www.airforums.com/forums/f438...ons-27999.html
cheers
2air'
Old 07-13-2010, 05:30 PM   #3
Many thanks,
F. A. Meloy
Generally speaking, Centramatics will not fit when using mag wheels, or with disc brakes.
You might call them direct and see if they came up with an answer.
Old 07-13-2010, 07:10 PM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I think you have that backwards. My Centramatics have been on my Kodiak disc brakes for tens of thousands of miles in the standard aluminum Airstream wheels. No clearance problems at all. However, when I had to use my steel spare wheel, the balancer did not fit
John W. Irwin
WBCCI #9632
Old 07-13-2010, 08:05 PM   #5
Francisco , Indiana
I installed Centramatics on my 2006 Classic. Aluminum wheels, disc brakes no problems what so ever. My tires show no signs of cupping and are wearing very evenly.
I looked and I have the dreaded Marathons from Goodyear, they are load range "E" came from the factory with them. So far so good.
Hickory
hickory is offline   Reply With Quote
Old 07-13-2010, 08:55 PM   #6
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
I have found three after market methods of balancing my tire/wheel assembly after they have undergone a shop balance using lead weights. The first is Centramatics. The second uses small ceramic beads that are put inside of the tire. The third is a liquid (similar to the green "snot" I use in my bicycle tires) that is injected into the valve stem. None of the dealers will provide me with anything more than the manufacturer's glowing reviews and a string of end user's testimony that reflects the vendor's claims. No one has posted a before and after summary with conclusive evidence that these things work and NTSHA hasn't listed any of the products as good or bad.
Problem is that the hubs on my 1976 are seriously out of balance and I don't really trust the 17 yo at Big O who can't decide if he should put the weights in one place or two. Also, my 1976 uses bolts instead of studs. Mounting a tire even without a Centramatic assembly in the mix is a problem. The cost comparisons and ease of use make the other two a bit more attractive. Another logistical problem seems to be is fitting the Centramatic between the wheel and hub. Anyone know if the aluminum wheels (presumably stock) on my 1976 (with a 1/2 in gap between the hub and wheel) will accommodate the Centramatics? Anyone have access to comparison studies of these products?
Eagle & Bear is offline   Reply With Quote
Old 07-13-2010, 09:59 PM   #7
richinny's Avatar
2011 34' Classic
get bolts and cut the heads off. thread them in on opposite sides of the drum and they'll help hold things while you start a few bolts with heads :-)
Ricky
Old 07-13-2010, 10:01 PM   #8
Centramatics
A special Centramatic, made to specs, must have a flat area on the back side of the wheels that is 10 inches.
Anything less, will not allow the balancer to correctly fit.
Most Mag wheels are fairly thick on the backside, and do not have enough flat area.
That is not to say that some mags will allow the proper fit, but generally speaking, the backside of the vast majority of them are only 6 to 7 inches.
Old 07-13-2010, 10:04 PM   #9
_
i also had the issue of the centras' NOT fitting behind a steel wheel spare,
while being PERFECT behind the alcoa alloys.
solution? i ditched the steel spare and replaced it with another alcoa.
_________
to the OP...
it saves TIME and frustrations to buy directly from the factory in texas...
Centramatic
OR use a vendor who understands FIT issues, like this one...
"Centramatic Automatic Truck Wheel Balancers will save you tires.Trucks and Hummers, wheel balancer, tire balancer, Centramatic,tire balancer for horse trailers,tire balancing,wheel balance,spin balance,tire rotation,18 wheeler,tire tread,wheel weigh
there's almost NEVER a need to guess about fit, unless the trailer or rims are WAY old...
i may just add a set 04 2 the truck now...
cheers
2air'
Old 07-06-2011, 06:44 AM   #10
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
Andy, if I am using drum brakes and these 16" wheels pictured below ... is that enough information to diagnose whether your special Airstream model Centramatics will fit? I know you have said that we must confirm that the surface of a 10" cake pan would fit behind the wheel ... must I remove a wheel and measure or can we conclude from others having successful installations (see GeneCrawford) that Centramatics will fit on mine? If so, specifically which model would I need to order?
Thank you in advance for any insight you can offer.
UAPachyderm is offline   Reply With Quote
Old 07-06-2011, 06:48 AM   #11
It's better to make sure instead of wasting money on shipping.
In order to install the Centramatics, you will have to remove the wheels anyway.
To be sure, take one wheel off and double check for the flat area.
If it's flat enough, then part # 13150 will work.
Old 07-06-2011, 07:09 AM   #12
redeagle313's Avatar
NE , Indiana
UAPachyderm: If you still have a 28' International, you have 15 inch wheels, don't you? Our 2005 28' International has 15 inch wheels, and they look just like yours.
Hi Yo Silver, Away II?
looking for our next AS
TAC IN-3
AIR 7185
redeagle313 is offline   Reply With Quote
Old 07-06-2011, 09:12 AM   #13
I changed to 16" wheels.
Old 07-06-2011, 09:13 AM   #14
Ok, will do.
2006 model year quality..... Silvertwinkie Airstream Trailer Forums 251 04-28-2010 03:07 PM
Year and Model Mr. Decent Forum Admin, News and Member Account Info 11 02-17-2009 08:42 AM
What exactly is it? model and year? aircooled4 Trailer Values 14 10-13-2008 09:08 AM
what model year? Lido&Linda Airstream Motorhome Forums 4 12-18-2003 12:18 PM
Suggestion: Airstream trailer Forums (by Model & Year) hex Forum Admin, News and Member Account Info 2 10-15-2002 06:38 PM
