Old 07-21-2014, 10:12 AM   #1
Razorhog's Avatar
1974 27' Overlander
2015 28' International
Little Rock , Arkansas
Question Can you run on three wheels?
Probably a crazy question ...
I had to change a tire this weekend and use my spare. I was wondering if you can run on three wheels in case of emergency?
Razorhog is offline   Reply With Quote
Old 07-21-2014, 10:14 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Not very far :-)
Remaining tire and hub on that side will get hot.
BambiTex is offline   Reply With Quote
Old 07-21-2014, 10:19 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yup. Just take off the flat. That's one of the advantages of a torsion axle.
2012 Dodge Durango Hemi/AWD
Old 07-21-2014, 10:35 AM   #4
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Fortunately and unfortunately, YES. Fortunately, you can get somewhere and out of harms way. Unfortunately the flat or blowout can damage your trailer. Case in point, blow out, not known till signaled by a fellow traveler, damage done. Was able to drive to local Walmart for an unplanned over nighter till we were able to organize the change of tire.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-21-2014, 11:09 AM   #5
You can also run on just 2 wheels, even if they are on different axles.
BUT, slow way way down, like to 25 to 30 MPH.
In that way, if you get a blow out, you would not lose control of the rig.
Old 07-21-2014, 11:42 AM   #6
1974 Argosy 20
Kooskia , Idaho
I had to do it once on the Alaskan highway. At that time, in the early 80's Airstream even suggested you could do it in their manuals.
Today I would be very careful about what happens to the single tire which remains. It will have been overloaded and could have become damaged internally, very easily. That sets you up for a blowout on that tire which has been stressed.
Old 07-21-2014, 01:36 PM   #7
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Last summer, north of Las Vegas, on the way to Reno, I had a wheel bearing fail. Brake drum, broke, I was able to save the wheel, and the tire.
To make a long story short, I pulled our 30' Excella, (loaded heavy), nearly 50 miles to the campground where we were staying. The next day, went into Reno, found the new brake drum, bearings, seals, etc.
It's possible, but drive slow, and pay attention.....
For whatever it's worth..
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 07-21-2014, 01:38 PM   #8
Venice , Florida
Images: 14
Good point, Andy about speed. Once we were aware of the tire failure we very slowly got to were we were going thankfully, a Walmart! Other than the 90 degree temp, we survived!
Airdreamers
WBCCI #8880
AIR #41310
Old 07-21-2014, 01:42 PM   #9
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
We made it for a few miles after we had a tire go. We didn't try to go far and we went slowly.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 07-21-2014, 01:50 PM   #10
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I think the procedure is still in Airstream manuals, it is in mine.
Doug and Cheryl
Old 07-22-2014, 12:44 AM   #11
Venice , Florida
Images: 14
What procedure is that?
Airdreamers
WBCCI #8880
AIR #41310
Old 07-22-2014, 06:19 AM   #12
dkottum's Avatar
From our Airstream Owners Manual:
"In an emergency, remove a flat tire. The independent suspension of the rubber torsion axle allows four- or 8 six wheeled units to be safely towed on three or five
wheels for a short distance (100 miles maximum) and
only at a low speed (30 MPH).
Be especially careful when crossing holes or dips in the road. Under these circumstances it is good practice to set your rear view mirrors so that you can observe your tires at all time."
Doug and Cheryl
Can you run both Air Conditioners with the Genset? Keyair Classic Motorhomes 4 08-26-2011 05:32 PM
DAY THREE.. if you're counting gregcomer Cleaning, Stripping & Polishing 6 10-17-2006 10:21 PM
Limping on three wheels with torsion axles...how? JimGolden Axles 12 02-13-2006 01:15 AM
