Old 10-23-2007, 07:15 PM   #1
1979 Argosy Minuet 6.7 Metre
Ridgeville , South Carolina
Can I lift my AS?
Is there any good way to raise my Argosy a little to give it a little more clearance in the back? What's the biggest tire that will fit inside the wheel-well and not scrub?
buzzbuck is offline   Reply With Quote
Old 10-23-2007, 07:18 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Height problem
I'll bet the axel is bad. That is how I determined mine was needing replacement. I did the deed and it raised the body about 4 inches, made a smoother ride and gave some peace of mind about spindle failure. I am sure Andy will chime in here with the correct data. Good luck on it.
Old 10-23-2007, 07:26 PM   #3
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Send a message via AIM to Airboss Send a message via MSN to Airboss Send a message via Yahoo to Airboss
Yes sounds like a axel job to me too.. I did my Caravel..Piece of Cake job Also helped DragNwagon do his dual axel 73.. It was even easier then the Caravel...His wife Rhonda has a thread on it here on forums...
"If your not living life on the edge... Your taking up too much room. WANTED, Single lady who loves and has a Airstream. Please send photo of Airstream and Tow Vehicle
Operation "SAVE RUDY" Strike Team (Charter Member) RALPH, KW8G..WBCCI # 4201 Metro Detroit & 4CU TAC # MI-007
Airboss is offline   Reply With Quote
Old 10-23-2007, 07:36 PM   #4
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
We have 6 meter Minuet. We replaced our axle with a Henschen that has a 35 deg. down angle and gained about 3-4" in clearance. No problems with the ride, I believe that it improved it. I also ordered 12" brakes vs. 10" it stops on a dime.
Peace
Gary
Janets Husband is offline   Reply With Quote
We have Lift Off! Ambie '64 1959 - 1965 Ambassador 7 11-26-2007 11:55 PM
Lift Off 48_liner 1947-1949 Liner 2 06-18-2006 09:44 PM
Motorcycle Lift? garjud General Motorhome Topics 0 12-30-2005 08:53 PM
Eaz lift ardenrj Hitches, Couplers & Balls 2 12-30-2004 07:03 AM
