Old 03-15-2015, 04:57 PM   #43
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by dznf0g View Post
So if you want 15% reserve on a p rated tire on a trailer, you shouldn't load beyond 75% of max sidewall stated load at max sidewall pressure?
I'm not the tire guy - but I think it's actually 76.5%.
If you had say a 100# capacity p-rated tire you'd only be able to use 90# (per DOT standard to de-rate them 10% for trailer application). Capri's 85% of the 90# would be 76.5# or a combined reduction of 23.5%.
So to apply BOTH the DOT standard AND Capri's 15% headroom recommendation for the Michelin LTX P235 75R15 that would equate to 1670# per tire (2183*.765) or just shy of 6700# for a double axle trailer. Mine weighs in at 5880# fully loaded (with FW tank full) for camping so I feel comfortable I've got even more headroom than needed (due to DOT) and recommended (by Capri).
Old 03-15-2015, 05:33 PM   #44
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Using those numbers I get 2050# per tire for the 16" Michelin (2680*.9*.85). That's 8200# total.
So even 16" tires aren't going to cut it for a newer 30' trailer (8800 GVWR)?
With the stock 15" Goodyear Marathons I get 2159 per tire (2540*.85, not derated 10%). That's 8636# total.
So, if I'm doing this right, using the 15% safety factor means the Airstream stock tires aren't sufficient.
I'm all for safety but maybe 15% is too much?
SCOTTinNJ is online now   Reply With Quote
Old 03-15-2015, 06:01 PM   #45
W , New England
The 16s are LT, not P rated so the 10% de-rating wouldn't apply. The next 15% is the recommendation of a tire engineer in the forums, not a requirement.
I would imagine everyone's mileage will vary on this. But actually weighing the trailer loaded for camping is key. You may find the 16s work for you or you may find you want to do something different. Lots of options.
Old 03-15-2015, 06:23 PM   #46
dznf0g's Avatar
Oswego , Illinois
Yup, didn't do the math...just off the cuff, quick and dirty.
-Rich-
Old 03-15-2015, 06:25 PM   #47
dznf0g's Avatar
Oswego , Illinois
Again that is and engineering recommendation for "over spec". I wonder if there is any margin already built into the original sidewall specs on tires....I know there is on GVWR....etc.
-Rich-
Old 03-15-2015, 07:43 PM   #48
2010 25' FB Flying Cloud
Davenport , Iowa
What happened to the day when we threw the wife, kids, dog in the station wagon and hooped up the tent trailer and went camping and enjoyed the week end?
Now we have to also consider the type of hitch, the weight on each wheel and if the trailer is loaded or unloaded. We also check the weight rating on each tire and where they are made.
We check the shocks on the tv and tt, how much downward pressure on the A frame and the list goes on and on.
We also check for different meals and how they are cooked; how about a hot dog and beans?
Camping is getting so technical that one almost wants to stay home or go to a motel.
Well,too much rambling.
LET'S GO AIRSTREAMING.
mike
Airtandem is offline   Reply With Quote
Old 03-16-2015, 05:07 AM   #49
CapriRacer
CapriRacer's Avatar
I'm in the , US
Scott,
You derated the LT tires and they do NOT need to be derated. Only P type tires need to be derated.
CapriRacer is offline   Reply With Quote
Old 03-16-2015, 05:09 AM   #50
CapriRacer
CapriRacer's Avatar
I'm in the , US
Yes, but both sides of the equation need to be done - design and utilization.
Old 03-16-2015, 10:33 AM   #51
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Originally Posted by CapriRacer View Post
Scott,
Thanks for the clarification!
That would move things to 2278 for the 16" LT tires, or 9112 total. Even more than the 15" stock tires.
Tires...Tires...Tires Bob Thompson Tires 277 07-30-2015 01:30 PM
Right sealants on the right sections BoldAdventure Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 11-22-2014 11:09 AM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 07:49 PM
The right acid works with the right applic got polish Cleaning, Stripping & Polishing 1 07-17-2008 08:50 PM
