Old 10-06-2010, 07:01 PM   #1
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
Broken Wheel Stud
Hey! All,
Today was the day to p/u the '06 Safari after having OEM tires replaced. After checking the Owner's Manual I started home on the 150 mile drive merrily checking and re-torquing the lug nuts as directed. 10 mile torque - fine. 25 mile torque - fine. 50 mile torque, using a break away torque wrench set at 115 lb-ft and I was dismayed to snap off the stud.
Oh! My. 100 miles left on the tow and my six-lug wheel was now operating on five lugs.
Some questions -
- first, how much disaster was I courting by deciding to continue the tow for another 100 miles? Or would I be advised in the future to pull over and spend the night until roadside assist rides to the rescue?
- second, is this a small job to repair? Large job?
- third, are A/S parts required or is it possible to wheel over to a local RV repair shop and use off the shelf parts?
- was planning on leaving for a weekend of camping. Sigh. IVO above, am I done for the weekend or is it possible to get fixed and back on the road quickly.
I surely don't want to drive 150 miles back to my dealer for repairs. Necessary? Not?
There are probably more things I need to know but this would be a start.
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
gsmithii is offline   Reply With Quote
Old 10-06-2010, 07:10 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
5 lugs should hold it on fine,I once towed 10 miles with 3 on each wheel. To change out the lug,pull hub,use large drift punch to knock out lug,take it to NAPA,they should be able to match.Pound in new lug,making sure it is flush. Remount the hub,brakes,wheel and retorque. Dave
easyride is offline   Reply With Quote
Old 10-06-2010, 10:28 PM   #3
lpatkins's Avatar
1976 23' Safari
Chauvin , Alberta
Agree with easyrider, not a hard fix and you should be fine for a few miles. Once lost a wheel when all the studs twisted off, did the repair in the ditch!
lpatkins is offline   Reply With Quote
Old 10-07-2010, 05:15 AM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
There are lots of videos on YouTube on how to do this. I didn't seen links because there are so many. Watch several of them and you will see it is a very easy fix.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 10-07-2010, 05:28 AM   #5
1971 29' Ambassador
Leonardtown , Maryland
I lost two wheel studs while in North Carolina drove home, about 100 miles. No problem. I was advised by my Dexter dealer to not replace the studs because of the possibility of the replacement studs working loose and making them impossible to remove the lug nut later. We replaced the hub. He had it for me the next day.
dale
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 10-07-2010, 06:40 AM   #6
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Drive the old one out w/hammer and punch(or bolt).
Drive a new one in w/hammer.
Rebee - you are correct....5 will hold
kennethowens is offline   Reply With Quote
Old 10-07-2010, 08:14 AM   #7
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Those studs are knurled and bite when driven in THEY WILL NOT COME LOOSE. I have replaced many studs in big trucks and cars in my years of wrenchin. Like kennethowens says Punch and a Hammer, Drive out the old, go ta NAPA match up the stud,Drive in the new DONE/ GOOD TA GO.
Good Luck
Roger\
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 10-07-2010, 09:15 AM   #8
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
I once drove my 2500 suburban with 2 missing posts, on the rear driver side wheel- from Detroit to Cape Cod and back, towing the 10k lb (and 1300lb tongue weight) trailer.
Of course, I had NO IDEA .
I check the trailer wheels regularly while in transit, but the truck- not so much. Shame on me for not checking the lugs… but shame on GORDON CHEVROLET in Garden City, MI for snapping 2 POSTS off- on a REAR BRAKE JOB, then screwing the decorative hub back on, and NOT TELLING ME.
Getting p*ssed all over again, just thinking about it…
I think a RANT post is in order…
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is online now   Reply With Quote
Old 10-07-2010, 10:42 AM   #9
1975 Argosy 24
Malakoff , Texas
Older models had "Lug Bolts" when they go bad - it is a little tougher.
Old 10-07-2010, 10:58 AM   #10
1989 29' Excella
Seattle , Washington
You just had a bad stud, 115lb should be fine, have you ever tried to get the nut off a wheel that you've had a new tire fitted to in a shop???, those guys must tighten them up to about 20,000,000,000 lbs. helava job getting them off.
Maybe worth changing out the other studs as well, as they may have also been in the bad batch
Streamer Dan is offline   Reply With Quote
Old 10-07-2010, 12:07 PM   #11
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
I would always suggest that ALL studs be replaced. Once you have it apart it is quite easy. The studs are fairly inexpensive and who knows why the first one broke. As the race people say "you life is riding on your studs" (or something like that!
mhilley is offline   Reply With Quote
Old 10-09-2010, 06:03 AM   #12
gsmithii's Avatar
Thanks All,
Before your helpful comments I was somewhere between "Dang! That could smart," and "This could be ba-ad."
Now it's possible to get a plan.
Skip
Old 10-11-2010, 01:09 PM   #13
1971 29' Ambassador
After I broke the studs i got concerned about the torque. I ordered a torque wrench on line. My book calls for 85 ft lbs with the cast aluminium wheels.
I believe I was over torqueing the studs
_________________
Rebee - WBCCI #1325
Broken wheel stud 65 Caravel kevinkatz Wheels, Hubs & Bearings 7 07-07-2009 06:31 AM
**Broken Wheel Well** Silvertwinky Wheel Wells 8 05-26-2006 02:57 PM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 06:34 PM
Wheel stud removal? TomW Axles 13 07-28-2004 04:42 PM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 02:25 PM
