Old 07-24-2018, 08:55 AM   #1
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Brakes and Never Lube Seals
Long story short -
We stopped by the factory in late March on our return from Florida and had some warranty work done and I also paid to have the wheels rotated and asked that the hubs be pulled to check on brakes etc. The left side (curb) had blown both never lube seals and brakes were covered with the lube - non functioning. Never knew and did not know when it happened. Dexter covered 100%.
Then this past week on a trip I noticed by TST Tire sensors showing the right rear wheel building up pressure. The other three were running about 86f, the right rear was running about 125f. So I pulled over and we heard a clinking noise. Middle of no where, not even cell coverage. So, pulled the trailer connection and ran without brakes or lights to the PA State Rally, 100 miles. No issue, but that wheel stayed hot, not as hot but hot.
Called Coach Net, they contacted a on road repair company who came out as scheduled the next morning. He pulled and sure enough the adjuster had broken in half, and messed everything else up. He pulled everything out, put and torqued the wheel back on and when we left the Rally we drove home with three brakes and lights. No issue at all as the F350 did it's job.
So, I called Dexter yesterday - only a few questions as to serial numbers etc and new assembly and drum on their way. They set up a repair facility near by or would have sent a road tech to do the job where our trailer is stored. Exceptional customer service and response.
The advice in the owners manual says to pull and check all four wheels and brakes every year or 10,000 miles - I think we will adhere to this policy, but we only have 8,800 miles on our trailer so the yearly check is important in my opinion.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 07-24-2018, 09:08 AM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
And donít forget that your TPMS alerted you to higher pressure from heat. That paid off well.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-24-2018, 04:02 PM   #3
paiceman's Avatar
It sure did and was actually the notice that probably saved us from anything worse. A great product.
SAFE TRAVELS
Bud
Old 07-26-2018, 10:47 AM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by paiceman View Post
Long story short -
Bud
Hi
If you have PA plates on the trailer, it gets inspected every year. I'm *sure* that they pull all 4 wheels as part of that inspection ......
Old 07-26-2018, 11:51 AM   #5
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Hooray for the TPMS! And kudos to Dexter for their service, though not for their parts that failed.
How hot do your tires get on a hot day? Do you think your tire was exposed to greater heat than ever before? Heat can harm rubber, but I don't know what the limit is for tires. There are a couple of tire engineers on the forum, but I am not one of them.
SSquared is offline   Reply With Quote
Old 07-26-2018, 12:19 PM   #6
GCinSC2's Avatar
This type of situation underscores what a TPMS really is good for, the unexpected.
You could have easily started this trip with a pre trip inspection including tire pressure and all was well.
But later as the brake problem heated up, this w/o TPMS could have been much worse.
My rig has internal sensors that monitor temp and pressure separately.
Also this is a reminder that periodic brake inspection is a good thing.
Safe travels.
S/OS #001
Old 07-26-2018, 01:05 PM   #7
paiceman's Avatar
Hi
We do have PA plates.
I do have PA plates, but pulling the plates is not part of the trailer inspection. "Checking the brakes is". Therefore, most places simply jack the trailer up and pull the safety cable out. So, your tongue in check comment is correct. Plus, pulling and checking the hubs is not part of any inspection and the broken spring which caused the adjust to snap would not have been picked up unless it had broken when inspected.
Bud
SAFE TRAVELS
Bud
Old 07-26-2018, 01:13 PM   #8
Half a Rivet Short
Bud
Hi
The gotcha with the above procedure is them leaving the safety cable out through the whole jacking process. It does not do the batteries any good. Don't ask how I know this ....
Old 07-26-2018, 04:27 PM   #9
paiceman's Avatar
Yep, wonderful experience. Fortunately itís part of our pre trip procedure. But then we once both missed the wire hook up and drove 200 plus miles with no lights or brakes, which is why I pretty much knew our recent experience would be ok
SAFE TRAVELS
Bud
Old 07-26-2018, 05:56 PM   #10
Bluffton , South Carolina
Paceman. Our Classic 30 came out of factory the end of February 2017 and we had same issue two days before Christmas.
69SoulShine is offline   Reply With Quote
Old 07-26-2018, 06:04 PM   #11
Make sure they send you a new drum. They didnít send ours first time around. And our repair guy said it need to be replaced because of all the damage from pieces flying around.
Old 07-27-2018, 05:37 AM   #12
paiceman's Avatar
Safe travels.
To respond to your post - we are both CDL drivers, my wife of over 25 years school bus and I was a sub for five years and do a double pre-trip inspection. NO pre-trip inspection would have found this issue unless it involved pulling the wheel and then only if the spring had already broken.
All wheels were pulled and inspected 500 miles prior to this incident by the Airstream factory.
Our TST system monitors both air pressure and tire temperature.
SAFE TRAVELS
Bud
Old 07-27-2018, 05:39 AM   #13
paiceman's Avatar
Our tires on a normal summer day run about 90 degrees on the "shade" side and about 94 on the "sun" side.
The dangerous tire temperature according to TST is about 147 degrees. Our sensors are set, by me, to go off with an alarm at 135. We did not reach those temperatures.
SAFE TRAVELS
Bud
Old 07-27-2018, 05:41 AM   #14
paiceman's Avatar
We were sent by Dexter a full assembled brake plate as well as a new drum and an additional brake plate for the other tire on that side as I told them that we now have two new brakes on the left side done at the factory and now this one that broke so I would appreciate a new brake on the remaining forth wheel. The CSR stated "we have no problem sending you the additional plate with the brake assembly". I received all next day via FedEx.
SAFE TRAVELS
Bud
Dexter E-Z Lube (not NevR Lube) Axles Al and Missy Axles 11 10-09-2017 10:06 PM
Dexter Never-R-Lube Inspection and Maintenance Ted S. Wheels, Hubs & Bearings 24 04-29-2017 06:09 PM
Dexter Never Lube axles boomerang1 Axles 1 07-21-2012 08:59 PM
Dexter Disc equipped axles never-lube bearings - maintenance dznf0g Wheels, Hubs & Bearings 4 08-17-2010 05:35 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 06:56 PM
