Old 08-30-2018, 10:22 AM   #99
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Originally Posted by jeberg1 View Post
I have a 2015 25 FC. Both right side Dexter brakes failed within the first eighteen months. First time caught in middle of nowhere. Drove to a town, bought a 1/2 drive breaker bar, and proper socket to remove Nev R Lube nut. Found magnet, broken actuator arm, and adjuster grinding away in bottom of assembly. After returning home I checked remaining three brakes and found broken parts in the right rear assembly. Bought replacement, Dexter assemblies, from E Trailer. Been to Alaska and back to Texas and other places
with no further issues. No issues on left side. Now carry a 24v impact wrench with all the necessary sockets. That Nev R Lube nut is a bear to remove.
And another one. The torque on the retaining nut must be 150# or the seal could wobble the rupture and leak.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 08-30-2018, 03:59 PM   #100
Bud
150lb torque? Thatís way too much, where did you get that figure?
0557 is offline   Reply With Quote
Old 08-31-2018, 07:04 AM   #101
paiceman's Avatar
Originally Posted by 0557 View Post
150lb torque? That’s way too much, where did you get that figure?
From Airstream and Dexter and if you pull the hub there is a plastic ring on it that clearly states torque must be between 145# - 155#. This is for NeverLub hubs. The high orque is an absolute must and all confirmed by two Airstream mechanics with over 70 years combined experience. When I called them about doing a change of brakes on my own the first words after saying, "sure it's not hard", but make sure you torque the hub nut to 150#.
SAFE TRAVELS
Bud
Old 08-31-2018, 07:39 AM   #102
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
You almost need to see a neverlube bearing cartridge to get the rest of the story. Iíve installed same design on my VW Bug press in and big torque to seat axle shaft.
Yup tag is on unit about torque.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-31-2018, 08:03 AM   #103
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Yep....
Old 09-08-2018, 06:42 AM   #104
GCinSC2's Avatar
Piaceman,
Did you ask about special tool on this VW job?
If so, YES. I borrowed a bearing press in/out tool from a friend. It uses a 3/4" fine thread bolt as the forcing tool and cups and drivers. http://https://www.harborfreight.com...ers-63728.html
I do think it would work to press out and press in a never lube bearing assy.
Dexter procedure http://http://www.dexterpartsonline....20Bearings.pdf
Same procedure.
Gary
S/OS #001
Old 09-13-2018, 04:33 PM   #105
paiceman's Avatar
Two hours and all four brakes changed to manual adjusting Dexter 12Ēx2Ē brakes. Brings back good memories and now if they work as well as the manual brakes did for us on previous trailers we will be thrilled. Drove 60 miles after and noted to achieve similar braking the Ford F-350 controller set at 6 instead of 6.5 or 7 on self adjusting, time will tell
SAFE TRAVELS
Bud
Old 09-13-2018, 04:48 PM   #106
GCinSC2's Avatar
Bud,
Got an IR temp gun? Great tool to read drum temps with.
Good luck,
Gary
S/OS #001
Old 09-14-2018, 05:04 AM   #107
paiceman's Avatar
Bud,
Good luck,
Gary
Nice, I used to work for IR and have a number of their impact tools.
Bud
SAFE TRAVELS
Bud
Old 09-14-2018, 06:02 AM   #108
GCinSC2's Avatar
Bud
Bud,
In a million years how could I use IR for infrared on an ex IR guy. That'll never happen again.
We're sheltering in place, Florence is saying good morning, I'm here!
Gary
S/OS #001
Old 09-14-2018, 08:53 AM   #109
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You have a gun from International Rectifier? I thought they mostly made MOSFETS ...
One gotcha with these temp guns is that they work based on light. It's not light you can see, but it's light none the less. It reflects off of shiny surfaces, just like the stuff you can see. What's shiny at IR? Well .... you can do the research. If it's gold plated, it's a pretty good bet it will reflect IR very well. Other metals .... that depends.
To the degree the object is white or black at IR, it will either absorb more or reflect more "light". Your temp gun is probably calibrated for a pretty dark black object. Use in on something that reflects IR well and the numbers will be off. We used to spend a *lot* of time spraying test objects with "known good" flat black paint before using IR thermometry on them. With the paint we could get within a few degrees C. Without the paint, the numbers could easily be off by tens of degrees C (yes C not F ... I never did anything in F my whole life at work .... ).
Lots of fun !!!
Old 09-14-2018, 12:56 PM   #110
paiceman's Avatar
Brakes and Never Lube Seals
Bud,
Gary
Ha
When I see IR I immediately think Ingersoll Rand. Be safe, heading south on the 23rd.
SAFE TRAVELS
Bud
Old 09-16-2018, 12:18 PM   #111
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
I used to use my laser infrared temperature gun to check my tires after reading some posts here; but it became easy to skip this check on some of my trips....so I decided to invest in a set of TST TPMS from Amazon after reading several posts here on the Forum again, on how the TPMS will give instant readings on heat and pressure and have saved several incidents before severe tire or brake issues occurred.
I just completed 2600 mile 11 day return trip from Montana thru parks in Utah and Colorado, thru New Mexico and back to Austin. Temperatures ranged from 30 degrees to 90 degrees as we got into Northern Texas. The TST TPMS color monitor sitting on my dash, consistently giving me instant readings on all 4 tires during the trip was great to have. Temps averaged about 10-15 degrees over outside temperatures typically. Tire pressures averaged 5-10 lbs over cold pressures of 45-47lbs on my new Endurance tires. Must say, I felt pretty surprised watching from time to time...Not sure why I put off so long. Good news is no surprises with my brakes or bearings.
Now, if I can figure out how to keep my trailer plug from coming loose from the F250 plug from time to time while driving down the road but, that's another challange for another day...
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 09-16-2018, 06:54 PM   #112
2007 22' International CCD
Consider going to an EZConnector System. Replace truck connector with a plug and play receptacle and add EZConnector adapter to trailer cable. Holds on with ridiculous strong magnets, very reliable connections and waterproof as well. Happy customer only...
Dexter E-Z Lube (not NevR Lube) Axles Al and Missy Axles 11 10-09-2017 10:06 PM
Dexter Never-R-Lube Inspection and Maintenance Ted S. Wheels, Hubs & Bearings 24 04-29-2017 06:09 PM
Dexter Never Lube axles boomerang1 Axles 1 07-21-2012 08:59 PM
Dexter Disc equipped axles never-lube bearings - maintenance dznf0g Wheels, Hubs & Bearings 4 08-17-2010 05:35 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 06:56 PM
