08-07-2019, 10:03 AM
#141
South East
, Michigan
Originally Posted by davidrrand
Mr. AirMiles:
Researching part numbers for replacement Dexter brake assemblies, drum hubs and bearings and read about recent issues with Nev R adjust units. The information that came with my AS on this is very confusing.
Dave R.
FWIW, my SOB came with the Dexter Never Adjust. After my second trip with them, I jacked up the trailer to check everything out. Brakes on two of the 4 wheels had adjusted so tight, I couldn't turn the wheel by hand. Had my dealer look at them and they talked to Dexter and reduced the tension. Next time I jacked up the trailer, two other brakes were over adjusted. Since I figured that wasn't good for the brakes, tires or MPGs. I said to hell with these and had disc brakes put on. No more problems. Trailer stops faster. AND if I blow a seal, I only loose 50% of the brake capacity on that wheel.
As far as I'm concerned, that was some of the best money I've spent on upgrades. I had Performance Trailer brakes do the install. They did the work at a park while I was on my way to my SOB brand rally at the Albuquerque Balloon fest. Took the guy about 5 hours. New brakes, bearings, and a relube. Very happy with the results. Had to decrease the gain on my controller. Also have learned that there is a slight delay in the brakes taking hold, maybe 1/20 of a second. But as noted, they do stop faster, so stopping from any significant speed mare than compenstates for the delay. Delay is caused by the electric hydraulic pump getting up to pressure.
Al
2017 29' SOB, 2022 Platinum F-150 SCrew, ProPride
08-07-2019, 10:21 AM
#142
2007 30' Classic S/O
Somewhere
, South Carolina
Al,
No doubt I'm a disc brake club member but a small correction.
I'm betting that any leak on your or my system is a complete system leak. We have one supply circuit feeding all calipers and any leak that pump will pump the reservoir empty right quick. It's not set up with dual master cyl system like our cars and trucks are. Drums, one goes bad, remove bad parts, cut magnet wire and you're at least able to continue.
I do carry a brake line union and plug. This allows in the event of a caliper failure that you can remove the supply hose/lone and cap it off. Now you can continue on with the remaining brakes to get repaired.
Disc brake fan.
Gary
08-08-2019, 07:20 AM
#143
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Originally Posted by rperrym
Understand the controller, but I was asking which gain setting you were now using.
Rick
Hi
Just to complete out the info, I had it up around 7 a while back. I've bumped it down a couple of times. More or less, bump it down, see how things do for a week or two of towing, bump it down a digit or half a digit and see again.
08-08-2019, 08:28 AM
#144
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village
, Arkansas
Thanks. I plan on adjusting mine as you did on our upcoming trip to the factory. I did put brake inspection on my list, and hope they hold up well on this trip.
Rick
2017 27 Tommy Bahama
2020 2500 GMC Duramax
08-09-2019, 07:22 AM
#145
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Rick
Hi
Pulling the wheels is not a cheap thing to have them do. That and the pulling over three times as you head out are the only real downsides.
08-09-2019, 08:10 AM
#146
Hot Springs Village
, Arkansas
Yes, I thought about the cost of doing it and the chance of them messing something up that is not a problem now. But I decided to err on the side of caution in case there is a problem waiting to surface on a long trip.
Rick
07-24-2021, 08:15 PM
#147
2013 31' Classic
billings
, Montana
Originally Posted by 69SoulShine
Because the spring broke
