Old 04-03-2016, 04:44 PM   #1
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Brake hubs and grease
Is there any justifiable reason to pack the center cavity full of grease when doing a repack and brake job.
Seems like a waste to me.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-03-2016, 05:28 PM   #2
r carl's Avatar
Lin , Ne
Its a waste unless you have a boat trailer with bearing buddies.
Old 04-03-2016, 05:52 PM   #3
That's not only a waste, but that would also create a huge problem, by destroying the effect of the brake shoes.
Some grease would slip out and get on the brake shoes. Then, NO BRAKES.
Cleaning the shoes with a grease solvent, is also a waste of time. If that was done, the very first time the lining got hot, more grease would come to the surface, again and again.
Ask those that tried it.
Old 04-03-2016, 06:24 PM   #4
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
That's what I thought, but I just wanted confirmation. Thanks.
Bruce
Old 04-03-2016, 09:09 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Disclaimer.....I know nothing.
If the cap has grease in it.....the grease in the bearings has no place to go.
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-03-2016, 09:17 PM   #6
dznf0g's Avatar
Oswego , Illinois
Likewise for the hub. Doesn't have to be completely full, but make a "dam" so grease in bearing has nowhere to go.
-Rich-
Old 04-04-2016, 12:04 PM   #7
1969 27' Overlander
Sun Lakes , Arizona
When packing bearings, regardless if you do the hand or press method, at the put a thin layer all the way around the inner and outer circumference. That all you need. Slide the inboard bearing into the hub and replace the seal. Slide the hub onto the spindle and the the outboard bearing, washer, locking nut, snug up and spin the hub by hand. After your satisfied that you have it tight enough install the cotter key and dust cap. Use a rubber mallet to install the dust cap.
Hope this helps
Tony
Redleger is offline   Reply With Quote
Old 04-04-2016, 12:36 PM   #8
dznf0g's Avatar
Oswego , Illinois
Boy, I guess my automotive school was way wrong...as well as my employer!
-Rich-
Old 04-04-2016, 12:55 PM   #9
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The purpose of coating the inside of the hub is only to prevent moisture from creating rust on the inside of the hub. Otherwise there is no reason for grease to be inside the hub. Grease was made to be in the bearings. Having more grease in the hub does not make the situation better. It only creates a mess and possibility of retaining heat in the hub.
>>>>>>>>>Action
Old 04-04-2016, 01:43 PM   #10
Question
Mine also.... We must have gone to different 'schools' together with the same instructor.
RLC
John Prine
Old 04-04-2016, 02:00 PM   #11
dznf0g's Avatar
Oswego , Illinois
Funny part is it has been multiple instructors. Guess they all be dumb. Although, to be fair, today's high temp SYNTHETIC bearing grease doesn't thin out and run out of the roller area as badly as petroleum (non-synthetic) grease does.
But, I still maintain, a "dam" of grease around the inside and outside of the cups is cheap insurance. Gosh a tub of grease that lasts several years must cost ...what $6?
-Rich-
Old 04-04-2016, 02:50 PM   #12
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I am not sure the type of grease matters.
http://www.brakeandfrontend.com/whee...what-when-why/
Heat does matter.
>>>>>>>>>>>Action
Old 04-06-2016, 07:59 AM   #13
2006 19' Safari SE
Hayes , Virginia
Bearing grease
You guys have been a wealth of knowledge to us all. One question, if I may.....How often do you grease bearings. Sorry for butt-in.
mocus is offline   Reply With Quote
Old 04-06-2016, 08:03 AM   #14
dznf0g's Avatar
Oswego , Illinois
I don't anymore! AS has Nevr-Lube hubs and disc brakes and I just sold my last vehicle with old fashioned bearings.
But previously, I packed trailer every 10K miles or 2 years, whichever occurs first. Still inspected, cleaned and adjusted brakes annually.
TV, every 15 - 25K miles
-Rich-
WTB 12" Kelsey Hays Brake Drums/Hubs 53Pontiac Airstream Classifieds 2 09-03-2014 06:16 PM
Do I grease the track the brake magnets ride on? amm3824 Brakes & Brake Controllers 3 07-20-2014 12:59 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
Replacing Front Hubs and upgrading Brakes on My 99 2500 Burb SaabLover Tow Vehicles 15 03-19-2008 05:09 PM
Grease on brake magnets lbrodsky Brakes & Brake Controllers 43 11-25-2006 07:06 PM
