Originally Posted by bwoodtx
Is there any justifiable reason to pack the center cavity full of grease when doing a repack and brake job.
Seems like a waste to me.
Just spent better part of day helping friend repair his missing wheel and hub on a tandem axle, #10k trailer.
From the looks of it, I'm guessing the outer bearing failed, and ground thru the stop washer... letting the whole wheel, and still lugged hub to freewheel off into a bean field somewhere. He had no idea how long he was riding on three-wheels.
He said it had been serviced (cleaned, replaced) about three years prior.
It's a Dexter with a zerk on the end of the spindle that he recently pumped copious amounts of grease into. The whole hub and dust cap was packed with grease.
I could see grease had escaped thru the inner bearing seal, and coated the magnet and shoes. Coincidentally, he mentioned very poor braking performance, of late.
The spindle where the outer race and bearing had ground down was scored, so I sanded it down, packed the new bearings full, lightly greased the whole spindle, cleaned all the surfaces and magnet (including magnet surface on hub) with lots of brake cleaner, then reassembled. Torquing the nut to 50 ft-lb, then backing off and finger tight.
