Old 05-19-2009, 10:06 PM   #1
mgordon's Avatar
Magnolia , Texas
Bolt pattern to get a spare
We did not get a spare with our camper when we bought it and need to get one. Has anyone figured out what the bolt pattern is to buy a new wheel/rim?
Michele Gordon
mgordon is offline   Reply With Quote
Old 05-19-2009, 10:16 PM   #2
They are an American standard.
You Airstream has 6 lug wheels.
The bolt pattern is called 6 holes on a 5 1/2 inch bolt circle.
Your wheels also have a "zero" offset.
Keep in mind that the correct wheels for your Airstream, must have a minimum of 2600 pound rating.
Old 06-06-2009, 06:28 PM   #3
1984 31' Sovereign
1978 Argosy 24
Zavalla , Texas
First message on the purchase of my first Airstream, a 1983 Sovereign 31 ....pick it up from being checked out Tuesday .... and of course the first question is about tires. Can I assume that the 83 bolt pattern is the same 6 lugs @ 5 1/2 inches as the 71 with a 7" wheel.
Cheerz
Orlop is offline   Reply With Quote
Old 06-06-2009, 06:37 PM   #4
Cheerz
Yes, but a 6 inch wheel.
Old 06-06-2009, 06:39 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Cheerz
Welcome to the forums. Yes, it is the same pattern, offset, and capacity.
Old 06-06-2009, 07:19 PM   #6
1984 31' Sovereign
1978 Argosy 24
Zavalla , Texas
Great, expect my eyes to be blurry from research on this forum for the next year~
Cheerz
Old 06-15-2009, 07:14 AM   #7
1984 31' Sovereign
1978 Argosy 24
Zavalla , Texas
by the way ..... there is no 83 Sovereign in the profile list. Saw the thread on the lack of documentation on an 83, but my certificate still in the trailer notes it as built in April of 83 with a "D" designation.
Cheerz
Old 01-29-2013, 12:44 PM   #8
1955 Safari
Air Stream 1's Avatar
1955 22' Safari
Enterprise , Alabama
Just purchased a 55 Safari with "off the shelf" aftermarket wheels. I assume they too are 6 on 5.5?
Air Stream 1 is offline   Reply With Quote
Old 01-29-2013, 01:48 PM   #9
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Vintage Trailer Supply dot com sells the correct wheel for your trailer, powder coated in black. It's a 6 on 5 1/2" bolt pattern.
Colin
Colin H is offline   Reply With Quote
Old 01-29-2013, 02:51 PM   #10
1981 31' Excella II
New Market , Alabama
I picked up a spare D-Rated for $100 at the local trailer place. This was tire and rim. It is not something that I would run 100% of the time but it should be fine for a spare. It is an ST rated tire = Bomb, so I will have to go slow with it.
Perry
Old 05-04-2015, 02:42 PM   #11
Lexington , Kentucky
Is the lug pattern the same for the 16" Airstream wheels (with the LT tires) the same as the 15" lug pattern. I have a set of Centramatic balancers for my current 15" wheels and wonder if they will fit my on-order Airstream with 16" wheels.
wlanford is offline   Reply With Quote
Old 05-05-2015, 12:17 AM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yes... the bolt pattern is on the axle/spindle side, so that does not change when you change the wheel from 15-16".... 6x5.5"... oh.. ZERO OFFSET for the Wheel, too.
Peace and Blessings..
Channing
WBCCI# 30676
shower curtain pattern Lana 1966 - 1968 Safari 31 01-26-2011 11:36 AM
Holding pattern hampstead38 1967 Overlander 5 05-23-2009 02:49 PM
Lug Pattern for 99 Safari Share All Wheels, Hubs & Bearings 3 07-05-2006 07:43 PM
Need pattern for original curtains roseyonnex Upholstery, Blinds, Walls & Interior Finishes 3 07-20-2004 01:59 PM
Curtain Pattern for '62 Bambi Marshall44 Upholstery, Blinds, Walls & Interior Finishes 15 03-17-2003 07:03 PM
