Tires and wheels Endless choices`
I seem to remember that a wheel attachment pattern of 5 holes on 5 inch center will fit both Ford and Dodge trucks. The choices of wheels is quite large. The factors to be considered are, number of axles, wheel pattern, wheel diameter, wheel offset, wheel load range, steel, alloy,and type of hub cap. Most off road equiptment use tall wheels with less rpm per mile, and can be moved over rough terrain. Most suggestions here will be mostly opinions and possibly not all options. Tire options are endless. All the tires with a high ply rating don't flex much to dampen the rough trails. The wheel that is 7 inches wide and 15 in diameter is a good trade off for all road conditions.
A trip to the local tire and wheel shop would be a good investment of time. On the net, there are many tire and wheel sources. Usually a local tire and wheel shop will mount some trial sizes.
Frank
Visit Idaho The people are great
