Old 06-24-2015, 10:14 AM   #1
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Best 16" Wheels ?
As a longtime Michelin fan I'm going to upgrade to 16" wheels and the appropriate Michelins pretty soon. My question is what 16" wheels are you using? Looks are important but I'm most concerned with price/performance.
John
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 06-24-2015, 10:35 AM   #2
Gainesville , Florida
If I were to change over I would get plain black disc wheels and get baby moons. Be sure the wheels have a high enough weight capacity. These would be a lot less expensive and have a different look than what most people are using.
Old 06-24-2015, 10:46 AM   #3
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Thanks for the input. I know from searching that Sendel aluminum wheels are a popular choice here. I'm wary of aluminum wheels as I had them on a Porsche rally car at one time and an inspection revealed a manufacturing defect that would have caused a catastrophic failure. I'm giving some thought to maybe using Maxxis M8008ST Radial ST225/75R15/10 tires on my original 15" steel wheels. I realize that they're trailer tires (ST's vs. LT's) but the reviews I have read are uniformly positive.
John
John & Vicki
WBCCI #4291
Old 06-24-2015, 10:47 AM   #4
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I happen to be fond of mine 16x6 Sawtooth Aluminum Wheel from AWC 3,200 lb load and rated for 100psi.
16 x 6 Aluminum Allied 870 Trailer Wheel 6 Lug with Center Cap and Free Ground Shipping.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 06-24-2015, 10:49 AM   #5
z , North Carolina
Well
This is what I and many others have mounted:
SenDel T03-66655BM
I got mine from trailer wheels.com
No complaints, and they look pretty sharp too. Not real impressed with the caps that came with them, but that's a minor complaint. They have lost that real shine. I was on a 16 day trek, with no place to wash the rims, and we travelled thru snow, mud, ice, hail and some very heavy rain. Rims look great, the caps...well..
Gavin
FishinHatteras is offline   Reply With Quote
Old 06-24-2015, 10:51 AM   #6
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
@Bold - Those wheels look great! Where are they made?
John
John & Vicki
WBCCI #4291
Old 06-24-2015, 10:56 AM   #7
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
@Gavin - Are the differences in the various models of SenDel rims mostly cosmetic?
John
John & Vicki
WBCCI #4291
Old 06-24-2015, 07:10 PM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Look long enough and you will be happy to avoid the 8008. The UE-168 Maxxis is good if it has the weight reserve, but one is much better off with 16" LT
As to wheel quality there are excellent American wheel manufacturers out there. But do they make trailer wheels to our spec? Yes, but
. For the most part it is China made if one will not pay more than $200/whl.
Old 06-24-2015, 09:27 PM   #9
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Note that the SenDel T03-66655T wheels are the ones installed at the Airstream factory on the Eddie Bauer models as well as the 2015 and later 31' Classics with a GVW of 10,000 pounds. These wheels are rated for a 3,580 pound load at 80 psi. There are two models, one with black high lights and the other plain aluminum:
T03BM | Sendel Wheels
Note that by using the same tire and wheel as the factory already installs on current models or will retrofit to any newer trailer brought to the factory, you could avoid any litigation for selecting the wrong equipment for your trailer in the event of an incident.
Using the 16" wheels, I chose the Centramatic wheel balancers model 300-356 "All 'A' plates, the Dill TPMS model #1506-453 tire pressure monitoring system (mounts inside the wheel as the valve stem) and the McGard 24138 Chrome Cone Seat Wheel Locks and McGard 64010 Chrome Bulge Cone Seat Style Lug Nuts (1/2" - 20 Thread Size).
SenDel makes the same appearance wheel in 15" diameter for the 23' Airstreams using a 14" five bolt circle so the original 14" drum brakes can be reused. In that case, my tire of choice is the Michelin LTX (P) 235/75R15 XL 2,183 pounds @ 50 psi derated to 1,985 pounds 28.9" diameter 4 x 1985 = 7,940 pounds 4 x 2,183 = 8,732 pounds. Run at 44 psi. The Centramatic wheel balancer for the 14" brake drum is the model 200-221.
The SenDel 15" wheel can also have the configuration for the 15" drum brakes as well with the Centramatic part number "200-221 Special" which is a six lug configuration. The other parts mentioned above could be used in this application as well.
Old 06-25-2015, 12:36 PM   #10
1982 27' Excella
Huntsville , Texas
The Al rims would look a lot better than the steel rims I have and the LT tires would have a speed rating more appropriate for driving Texas roads. However, when I looked in the wheel wells of my 1983 Excella I was really concerned about clearances. The tires did not have any excess clearance with the standard trailer tires.
GMarugg is offline   Reply With Quote
Old 06-25-2015, 12:39 PM   #11
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We ordered our 2015 30' FC wit 16" Michelins and the factory mounted them on Sendel wheels.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 06-25-2015, 01:16 PM   #12
2011 30' Flying Cloud
Greenback , Tennessee
I labored long on just the same decision. I finally elected to go with the 15" Maxxis tires for our 2011 FC 30. I was almost ready to bite the bullet and opt for new 16" wheels and Michelins, when I remembered I would have to buy five of each, since my 15" spare wouldn't work any more. I figure the Maxxis are worth trying, as I have read some good things about them. I will install them with Centramatics and hope for the best. If these prove unsatisfactory, then I will go the 16" route.
Gneiss Guy is offline   Reply With Quote
Old 06-25-2015, 05:33 PM   #13
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
What are "Centramatics"?
MelGoddard is offline   Reply With Quote
Old 06-25-2015, 06:31 PM   #14
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Got my wheels, tires and Dill TPMS thru Discount Tire from http://www.hispecwheel.com/ previously documented.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
From 14" wheels to 16" wheels Air Cruiser Wheels, Hubs & Bearings 24 09-16-2011 07:18 AM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
