Old 07-05-2013, 04:54 PM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Bearing seal
Hi all, im servicing the bearing on my 59 tradewind and when i popped the bearing and seals off i noticed the seal body had a circular scuffing pattern on it. It appears that the inside edge of the bearing body was rubbing on the outside portion of the bearing seal. My question is if perhaps i packed the seal into the hub too tight? If that is the case what is the technique for packing the seal into the hub? My technique for the castle nut is to hand tightnen it with some channels locks, thenback it off until the cotter pin slides in. Thoughts? Why the wear pattern?
steveirving is offline   Reply With Quote
Old 07-05-2013, 04:58 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sounds like the seal was set too deep??
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 07-05-2013, 05:45 PM   #3
Olie's Avatar
2004 30' Classic
Beaumont , Texas
I agree with cwf . You probably drove the seal in too far.
Just tap the seal in evenly with the drum lip and no more. The castle nut has nothing to do with the grease seal.
Olie is offline   Reply With Quote
Old 07-05-2013, 07:06 PM   #4
1959 24' Tradewind
Quantico , Virginia
Images: 11
That does make sense now that i think about it. The castle nut pulls the rwo bearing tight onto the spindle, so putting the seal just flush with the drum lip will create a seal and should provide a small cavity for grease to circulate. When i first pulled the drums and seals out after getting the trailer this is how they were set (below the rim of the drum against the inner bearing. Is this incorrect?
Old 07-05-2013, 07:09 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup that is wrong to seat that deep
Channing
WBCCI# 30676
