Old 06-07-2014, 07:56 AM   #1
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Bearing part numbers
Does anyone know the part numbers for the wheel bearings (12" brakes). The seal number would be helpful as well. I have seen them on the site but can't seem to re-find them. I recall that they changed in the late 1990's. Thanks.
mhilley is offline   Reply With Quote
Old 06-10-2014, 08:16 AM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
The outer bearings are LM 67048 ( Timken #)
race - LM 67010 ( Timken #)
inner bearing - 25580 ( Timken #)
race - 25520 ( Timken #)
Double lip seal, Redline trailer parts # 10-36
seals can come from different manuf. and may use different #'s but I suggest always use double lipped seals. I got mine from a local trailer supply. They run about $8 / pr.
Keep in mind if replacing the bearings the races ( cones) should be replaced also. I got mine using a website, locate ball bearings.com
they are knowledgable and very helpful.
Of course these fit my trailer and probably will fit yours too. Double check
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-17-2016, 08:33 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
.....Snip.....
I assume these parts will fit both of my trailers, 1999 and 2000 with 12" brakes. Correct? I can't find a specific bearing number listed in the parts manual for my trailer. It only lists the axle assembly. When I look at ODM and InlandRV websites I found there are two outer bearings offered for axles with 12" brakes, but to me it is not clear to me which I need.
The Timken bearings I find online are made in China. I've been trying to find some USA made bearings. What brands are made in USA?
Old 04-17-2016, 08:50 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Another bearing question:
When I searched the forum I see some people have referenced "bearing set numbers". I'm assuming this is a set of a bearing and a race purchased together.
Is that a correct assumption?
Which set would be appropriate for my trailer' inner and outer bearings?
In my 25+ years of towing Airstreams I've never needed to replace a bearing. But, I'm getting ready for a 6,000 mile tow this summer. I want to have a spare set.
Bearing Race part numbers ???? polarlyse Wheels, Hubs & Bearings 12 01-11-2014 08:05 AM
Bearing & Seal part numbers Jeepjunk4 Wheels, Hubs & Bearings 4 10-14-2013 08:48 PM
Industry Bearing Part Numbers Here dbj216 Wheels, Hubs & Bearings 2 01-02-2013 05:01 AM
16' CCD Wheel Bearing & Seals Part Numbers RDM16CCD 2005 and newer - Bambi all models 0 05-21-2009 04:37 PM
I need numbers, Part numbers that is. thenewkid64 Airstream Motorhome Forums 1 07-19-2003 10:51 AM
