Old 05-11-2013, 05:31 AM   #1
"Sassyfras"
oledawg's Avatar
1994 30' Excella
Winston-Salem , North Carolina
Bearing Buddies
Anyone use Bearing Buddies on their Airstream? I use them on my boat trailers and they are great. Just curious ;-)
Raconteur, Bon Vivant, Curmudgeon, and other depending on Susan's mood at the time...Retired, so don't ask me to do a damn thing
oledawg is offline   Reply With Quote
Old 05-11-2013, 05:48 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Decide for yourself....
I have them on a boat trailer also, they work well when the hubs are submerged on a regular basis.
On the AS I feel it's better to inspect once every Spring and be SURE everything is ok.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 05-11-2013, 06:43 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Not just no, but hell no.
If anybody from our shop recommends them, they will be dragged outside and summarily shot.
They work well for their intended purpose, which is to force water back out of the hubs when the hub gets submerged. If you are towing your Airstream through water deep enough to submerge the hubs, you have bigger issues than needing bearing buddies.
Old 05-11-2013, 06:53 AM   #4
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Overlander is right not a good thing. Understand that putting grease forcefully in without being uncapped, air or grease has to go somewhere, soooo pushing it past the inner seal into the drum brakes is not a good thing. Some easy lube axles actually have a hole drilled in the axle hub center opening at the rear to force grease inside out to where you are pumping, see grease it's full. Airstreams do not have this feature.
arcamedies is offline   Reply With Quote
Old 05-11-2013, 06:55 AM   #5
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Well, that is a clear!
Silverflames is offline   Reply With Quote
Old 05-11-2013, 07:23 AM   #6
2013 20' Flying Cloud
Cream Ridge , New Jersey
I have always thought that Bearing Buddies were a bad idea. once the hub and bearings are full of grease, the amount of pressure required to force the heavy grease out the tiny hole into the axle tube is more than is required to pop the seals. If you get water in the bearing grease you now have a huge sloppy mud pie that has to be removed from inside the hub and cleaned before re-assembly of the bearings. I have removed them from my boat trailer axle completely. I have built a system where I can apply a tiny bit of air pressure inside the axle tube when I launch and retrieve my boat. I pack the bearings the normal way. The little bit of air pressure inside the axle tube also forces the seals to grip the spindle a little tighter. When I launch I look for air bubbles trying to escape. There shouldn't be any. If there is, I have the pressure too high. I figure if there's a place for water to get in then there's air pressure right there to push it out. I have been testing this system for three years now and have not found a drop of water in the grease when I inspect and re-pack the bearings every year. The Airstream axle is not designed to relieve any internal pressure that I am aware of and I wouldn't even consider installing Bearing Buddies on an Airstream.
Joe Palmieri is offline   Reply With Quote
