Old 10-12-2013, 12:10 PM   #1
1990 29' Excella
Long Island , New York
Bearing & Seal part numbers
I need part numbers for my 1990 excella. The outer bearing looks like a Timken LM67040 although hard to read, the inner is a bower 4T-25580 maybe? The grease seal has no numbers at all on it. Anybody? Trying to locate at an auto parts store this weekend, was hoping to get out of here early next week.
Jeepjunk4 is offline   Reply With Quote
Old 10-12-2013, 02:00 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
There is a number on the seal. Took me a long time to find it. Clean the seal, wipe it clean, and look at the outer surface with a magnifying lens. Number molded in about 1/32 inch high. Once we found the number NAPA could match it up easily.
Old 10-12-2013, 09:06 PM   #3
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I would just take the bearings and seal to a NAPA store and let them match up for replacements. I have done this before and they had no problem getting the correct parts for me. Quick and easy and you will get to compare the old and the new parts side by side before buying.
Sam
samb is offline   Reply With Quote
Old 10-12-2013, 10:55 PM   #4
The correct bearing numbers are LM 67048 and 25580.
Rarely does an auto parts store have the correct grease seal.
You should use a double lipped seal that also has a spring in it.
They are readily available from parts stocking dealers.
Old 10-14-2013, 08:48 PM   #5
1990 29' Excella
Done!! Thanks all for your help.
What do the red numbers mean perryg114 Clearcoat, Exterior Paint & Trim 2 12-28-2012 05:15 PM
Displaying TAC numbers DougZ Other Clubs 46 01-01-2012 07:01 AM
What is this part? (front end shelf) SpaceEgg General Interior Topics 2 01-09-2011 05:11 PM
Part # Duo therm penguin gasket? HCR Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-09-2011 12:27 PM
