02-28-2014, 08:44 PM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Battery Impact Wrench
I'm curious how many might carry a battery impact wrench with them for removing lug nuts. Saw one used on a vehicle today, they sure are slick for removing lug nuts. If you have one, what brand is it? How well does it work? Thanks!
Indiana, PA
TAC PA-5
WBCCI 4871
02-28-2014, 08:53 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I have a DeWalt 1/2" drive and a Milwaukee 3/8" drive, both work very well.
02-28-2014, 09:44 PM
Durango
I use a corded Makita or a Dewalt as I have a generator.
02-28-2014, 11:35 PM
1978 28' Ambassador
Morada
I use a battery powered 'Goodyear' brand from a local auto parts store several years ago...It had a $20 rebate - SWEET!
I use it to lower and raise the four stabilizers - quicker and more powerful than a cordless drill, IMHO...
Keep it in the trailer's storage compartment so it's ready to remove the wheel lug nuts if required on the road...
It could also be used on the tongue jack if the electric motor gives up the ghost...
As you can see, it's 'mush have' in our tool bin...!
Ray & Pat; Morada, CA
03-01-2014, 06:05 AM
Retired.
, At Large
I use one regularly at work. I even use it to adjust hitch heads on the tow vehicles, as well as lug nuts. At 475 pounds of torque, I have to be careful not to twist off the studs on the lugs. And it's very portable.
03-01-2014, 06:14 AM
1960 26' Overlander
1963 24' Tradewind
El Paso
I found a used Snap on 1/2 drive impact/flashlight combo kit. Great tool.
03-01-2014, 06:39 AM
2001 34' Limited
Tucson
When we travel I got into the habit of bringing along the Cordless tool bag. Drill, light sawzall and a small impact. Even though it's an 18volt set the impact doesnt have enough "Uumph" to break loose the lugs on tires. In it's defense however, it's not what it was designed for either, it's an impact driver made for screws. I use a tire iron to break the lugs loose, and the driver to speed the threading on/off of the lugs.
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
03-01-2014, 08:41 AM
2002 30' Classic S/O
Garden Valley
, Idaho
I have the Sears version and charge up both batteries just before a trip. It is an awesome thing to have even though with my new Michelins, I hope I don't need it. The one thing you should think about is your lug nuts. On my 2002 AS, the lug nuts are a 2 piece variety with a stainless shell over a steel nut. I highly recommend you change out all of the lug nuts to a solid stainless type. The 2 piece lug nuts are crap and will come apart.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
03-17-2014, 12:21 PM
Moderator Emeritus
1972 31' Sovereign
High Springs
Bought a "Goodyear Racing" battery impact from Pep Boys about 8 years ago. A real life saver! Battery went kaplooy after 5 years, and I had it rebuilt at Interstate. Cost almost as much as the whole kit! But better battery.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
03-17-2014, 01:27 PM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
Not quite the same, but I carry a 110 volt harbor freight impact wrench. It runs of a 1000 watt inverter in the truck.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
03-18-2014, 06:30 AM
ottawa (greely)
, Ontario
I have two pneumatic impact guns one is a1/2 inch drive husky the other is a 1/2 inch ingersoll and to answer your batterie type impact gun ,I have a snap on 3/8 impact gun it works great love it ,but will only remove nuts at 90 and below foot pounds of torque ,I use it around the house never bring it with me.
03-25-2014, 08:58 PM
1988 29' Airstream 290
San Francisco
The DeWalt 1/2" 20V impact wrench is great. It has 300ft lbs of torque - it's incredible. I used it the other day to take an alternator pulley nut off - without locking down the stator. The torque came on so quick it just spun the nut off before the alternator internals had a chance to start moving.
