Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Old 08-14-2009, 12:16 PM   #1
rochar3's Avatar
Profile:  2003 31' Classic
Valparaiso , Indiana
Balance or not
I didn't want to start a new thread, but I can't find any info on balancing AS tires. Is it necessary?
Bob-air # 657
I can win any argument on any subject. People know this and steer away from me at parties. Often as a sign of their respect, they don't even invite me.
rochar3 is offline   Reply With Quote
Old 08-14-2009, 12:18 PM   #2
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
Yes, it's necessary, and some say you even have to ballance the wheel/tire/and brake drum as a unit.
If they are not ballanced the resulting shake can damage the trailer.
Old 08-14-2009, 12:31 PM   #3
Lynn
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
Bunches of folks have switched away from regular balancing to use either dynabeads or centramatics. It's considerably more money up front, but well worth it in the long run. Inland Andy carries the centramatics now.
Lynn
WBCCI 21043
Angel Fire, New Mexico
Old 08-14-2009, 02:15 PM   #4
Profile:  wh , Arizona
Lynn
??What are these?
Gypsy Jo is offline   Reply With Quote
Old 08-14-2009, 02:24 PM   #5
Lynn
eubank's Avatar
It's a doo-dad that mounts between the wheel and the drum with weights that flow about as the wheel turns, keeping the whole business in balance. Here's a pic from Andy's site:
Lynn
WBCCI 21043
Old 08-14-2009, 02:30 PM   #6
Interesting!! Can they be used on motorhomes.
Old 08-14-2009, 03:05 PM   #7
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Airstream Registry
Yep. The manufacturer makes these for tractor trailers also. http://www.centramatic.com/balancer.html
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 08-14-2009, 03:13 PM   #8
JimGolden's Avatar
Profile:  1987 34' Limited
The best thing to do is to pull the drums off (if they're in good shape...otherwise buy new ones) and take them to a machine shop and have them balanced. Grind off the flange on the heavy side until they dynamically balance.
After that, you MUST CERTAINLY balance the wheel/tire combo.
Now you are shake free and go have a happy day
- Jim
JimGolden is offline   Reply With Quote
Old 08-14-2009, 03:22 PM   #9
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Airstream Registry
Absolutely Required Unless....
Lynn
Yep...balanced running gear (as in tire, rim, and hub) is critical to the life of your AS unless you want to see things come apart.
I've heard good things about the centramatics.
And thank you Lynn for correcting me as I now know Doo-dad is hyphenated. And to think I'd been spelling wrong all these years!
I love picking up the finer points of technical jargan!!! OK....I'm off my smartie pants podium.
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Old 08-14-2009, 04:11 PM   #10
Lynn
eubank's Avatar
Ah, well, doo-dad just seems right. Could be a doomaphlage, though.
Lynn
WBCCI 21043
Old 08-14-2009, 05:19 PM   #11
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
The centramatics Do not replace balancing the wheels and rims... You still need to balance the tires and rims. the centramatics just keep it in balance better and they don't start working till you get to about 30 mph...
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-14-2009, 05:55 PM   #12
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
The faster a mass spins and the further away from the center (spinning point) a mass becomes the more critical it is to have that mass in balance on all planes.
For an Airstream, it means having in balance tire/wheel assembly causes less damage to the rivits and structure of the trailer. Because the skin is part of the structure of the trailer.
Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.8L, E4OD, 3.55 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 08-14-2009, 06:43 PM   #13
Profile:  1977 31' Sovereign
1969 23' Safari
Port Angeles , Washington
dynabeads same to be the same principle, but in the tire instead of between tire and drum $40 including tools and applicators for 4 15 inch wheels as opposed to $200 for the other type!
anami is offline   Reply With Quote
Old 08-14-2009, 06:50 PM   #14
1969 23' Safari
oh and i found this by google as far as other threads on this
Getting Running Gear Balanced?
Driveshaft balance on MH RichardT Airstream Motorhome Forums 3 12-07-2004 11:47 AM
How To Balance Running Gear Inland RV Center, In Axles 26 07-08-2004 03:14 PM
Running gear balance? Cedars Axles 79 06-10-2004 02:57 PM
Tire balance Melvin P. Thorpe Tires 12 12-30-2003 07:21 AM
RV weights and balance gwsullivan Link Archive 0 08-21-2002 02:50 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
