Old 05-17-2017, 04:17 PM   #1
LSP
Pinnacle , Arizona
Baby moon caps for 1966 sovereign
Where can I find these old or new?
LSP is offline   Reply With Quote
Old 05-17-2017, 04:35 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I bought set from JC Whitney for my 64 Bambi II.
MICHAEL
Old 05-18-2017, 04:20 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Almost a decade ago I bought a used set at Arizona RV Salvage for a '66 Overlander.
e.com/
Smaller parts like this, they do not list on their website. I found period correct baby moons that had originally been on a Silver Streak.
I used this place to buy a few other things as well. The largest piece was a roof top AC unit. Came with installation instructions and a warranty even though it was used. It had been tested and worked well.
>>>>>>>>>>>>>>Action
Old 05-19-2017, 04:52 AM   #4
LSP
Pinnacle , Arizona
AWCHIEF, thanks for the reply! I looked there under Baby Moon Hubcaps and tried a few other names. I came up with nothing. I'll continue to try different names. Thanks for the help.
Old 05-19-2017, 04:55 AM   #5
LSP
Pinnacle , Arizona
Thanks for the tip! I'll call them today and see what they say!
Old 05-19-2017, 08:17 AM   #6
1967 17' Caravel
www.wheelsmith.com ?
David F is offline   Reply With Quote
Old 05-19-2017, 08:31 AM   #7
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
try Vintage Trailer Supply, they advertise here and had the ones that I needed for my '58 Traveler
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 05-21-2017, 08:29 AM   #8
LSP
Pinnacle , Arizona
Thanks for the input ! I checked and all they had was rim knock on style. I have the inner clip style. I believe I did find some on www.Mrhubcap.com. Thanks for your time
Old 05-22-2017, 08:02 AM   #9
1958 18' "Footer"
Not trying to push you any way to purchase but here are the links, the have a few types here.
http://www.vintagetrailersupply.com/...caps-s/406.htm
and these are what I needed
http://www.vintagetrailersupply.com/...-p/vts-690.htm
more for others looking than anything else
Steve
Old 05-23-2017, 03:04 PM   #10
LSP
Pinnacle , Arizona
I have looked at vintage trailer supply and have purchased some of there merchandise. It does seem very good quality. There Baby Moons look very nice! The only thing that worries me is my clip to clip is eight inches and they are saying 8 1/8 which isn't much I know. Spring tension is how the clip style works so larger isn't good. I will order one and see how it fits. I have to order some window clips soon also.
Thanks Prairieschooner
Old 05-30-2018, 06:36 AM   #11
1965 22' Safari
California , Kentucky
original hub caps
I purchased new steel wheels and my original caps use clips which are not present. Any way to adapt them? Hope this is the correct way to enter this conversation. thanks in advance for any and all advice.
RiverRat is offline   Reply With Quote
Old 05-31-2018, 02:50 PM   #12
LSP
Pinnacle , Arizona
RiverRat, I would imagine you could grind off the rivers on the back of the wheels for the clips and rivet them on to the new rims. You’ll have to drill the holes first of coarse. Otherwise you might be able to go to a knock on style baby moon now and not even need the clips or the clip on baby moons! If you do do this I would be interested in buying those clip on baby moons from you! Let me know!
Old 05-31-2018, 02:51 PM   #13
LSP
Pinnacle , Arizona
I sent you a message in the thread. Sorry I’m new to this!
Old 06-01-2018, 09:15 AM   #14
1965 22' Safari
Moons
Well the idea is to keep everything original as possible so thinking a good welder could come up with something but so far zilch. Old wheels are history (split rims)
These old moons might be stainless? Searching......
1966, sovereign
1967 Tradewind wheels and baby moon caps Snellen 67 Airstream Classifieds 0 08-21-2014 10:23 PM
Baby moon hubcaps Lothlorian Wheels, Hubs & Bearings 6 11-14-2009 03:44 PM
steel wheel baby moon clips greenrig Wheels, Hubs & Bearings 8 06-24-2008 12:31 AM
