Old 03-18-2014, 06:37 AM   #1
ottawa (greely) , Ontario
Axle seal part number for 2012 19 foot Flying Cloud
Does anybody have the part numbers for the axle seals because I'm going to repack my wheel bearings ,I have not checked the dexter axle serial number yet,but in air streams brochure they say gross vehicle weight is 4500 lbs so not sure what axle is on there.if you have the part number please specify manufacture of seal ,thanks!
scamp is offline   Reply With Quote
Old 03-18-2014, 07:36 AM   #2
1988 25' Excella
Trumbull , Connecticut
Hello Scamp. On the seals that I have replaced there is a MFG part number stamped on the seal and most auto parts store will have them.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 03-18-2014, 08:32 AM   #3
There are many inferior subsitutes, as well as very cheap.
Make sure the replacements are double lipped and with a spring.
Old 03-18-2014, 03:35 PM   #4
Update my dexter axle is part number pn 410980-06 there is another number 1616620
Old 03-18-2014, 04:25 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The Airstream part number is 680370-100.
You should be able to call or go to any Airstream dealer with that part number, and get the correct seals.
Old 03-19-2014, 10:06 AM   #6
Your first number is the part number of the axle.
Have no idea what your second number is for.
Old 03-19-2014, 06:09 PM   #7
No dexter or aftermarket grease seals in stock at dealer or two other rv dealers in town ,must order if I want dexter seals three weeks or to get aftermarket seals they can be ordered but will take two days,even airstream dealer said three weeks to get them ,here is the dexter part number 010-054-00 ,plus other manufactures , trans com 22333vb, national 442109, nok af3135g1, Chicago rawhide 22550, tru Ryde 42385, ap 014-122088-10 , well sure glad I didn't knock them out of the drum ! So I just repacked the outside bearing and added grease to inner ,serviced the brakes and cleaned the rust off the brake magnet surface on the drums and brake shoe surface. Will wait to get some seals at jackson center .then repack bearing properly.
Flying high on a Cloud from 1958 MontanaAIR 1956 - 1959 Flying Cloud 110 01-23-2012 01:13 PM
25FB Flying Cloud danlehosky Dollars & Cents 5 10-27-2011 10:10 PM
2012 Flying Cloud flyingcloud Airstream Trailer Forums 5 09-13-2011 02:02 PM
New member w/new Flying Cloud & TV raguemoe Member Introductions 5 04-29-2011 03:45 PM
