Old 01-23-2014, 03:50 PM   #1
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Another Darn Wheel Bearing Thread ... 10" Brakes
This post may be applicable to most 'newer' Airstreams with 14 inch wheels and 10 inch brake drums, i.e. 23 footers and shorter.
I thought it would be a good idea to carry a spare bearing set with me, so after reading all the applicable threads, I was down to the bearing supply store today. No problem with the cups and cones (races and bearings), the part numbers in the Parts Manual for my '09 FC are clear. The grease seals were more difficult, a previous thread indicated that Timken #473336 should work, but my supplier came up blank on that one. A cross-reference book suggested that the SKF double lip #17146 should fit the bill. Dimensions are not quite right at 1.719 X 2.561 X 0.5, but the dealer said that there is room for some tolerance on the grease seals.
Does anyone know through recent experience the correct Timken part number for this seal, and/or whether the SKF seal that I purchased is correct?
Below is a photo of the parts for replacement of bearings/races/seals for one wheel. In case you're interested, my cost was 45.14 Cdn for these parts including GST.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 01-24-2014, 11:55 AM   #2
TinTin's Avatar
Canmore , Alberta
Just one gentle bump ...
Bob and Nancy
Old 01-24-2014, 12:05 PM   #3
TinTin's Avatar
Canmore , Alberta
I found an old post by Andy at Inland RV indicating that the bearing size for 10 inch wheels is 2.56" OD, 1.719"ID, double lipped. Based on that, the SKF 17146 should work just fine.
Bob and Nancy
Old 01-24-2014, 12:17 PM   #4
1974 Argosy 20
Kooskia , Idaho
BTW not all short Airstreams have 14" wheels. I don't know the brake size on my new 20' FC but it came with 15" wheels, which have since been changed to 16" ones.
Old 01-24-2014, 12:18 PM   #5
TinTin's Avatar
Canmore , Alberta
Thanks for the heads-up idroba!! Seems that the 14 inch wheels are only standard on the 23 footers (the shortest AS with tandem axles).
Bob and Nancy
