Old 11-08-2013, 06:02 AM   #15
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Very interesting thread.
I have noticed the typical Dexter drum will quickly and consistently rotate to the heavy spot down condition. I have asked Dexter about balancing drums and they don't seem to think the drums are any big deal.
I don't agree, but I don't see much chance they will change their policy
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 11-08-2013, 06:43 AM   #16
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Bruce,
Very good info here.
Kind'a glad I've kept my USA OEM Alcoa's. No problems with lug seats, cracking or corrosion. TGFSF.
Realized quite quickly when first getting the Classic that something had to be done about balancing the running gear.
Took the wheels/tires to work to road force and still had a vibration at cruising speed. Short ride in the AS was very enlightening.
Researched the Centramatic's and installed them second Season.
They have worked flawlessly since installation.
Any Sendel update?
ID:	199554   Click image for larger version
Name:	AS STUFF 012.jpg
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-08-2013, 10:54 AM   #17
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
When I worked for a domestic auto manufacturer the quality difference between that manufacturers stock wheels and an aftermarket was extremely noticable. That was in the '80s. I would assume quality standards would have improved for every manufacturer whether aftermarket or not. And yet this thread seems to point out that at least one aftermarket wheel manufacturer may have some quailty issues.
In the world of aftermarket, typically looks and price usually get a front seat to function. This thread is a very good document to checking the function of something we see every day. Non-standard wheels on all kinds of vehicles. Thanks Bruce!
When making a switch in any running gear piece make sure it is up for doing the job. Most of the running gear pieces AS uses they do not produce rather they contract out for these assemblies. So quality at the point of manufacturing isn't in their direct control. As it is posted in this thread (and else where) drums are an item that may need to be addresessed on amy one's trailer as it seems there is no tolerance for balance on that item. (It isn't so critical on discs) If the drum is or isn't balanced it is a hit or miss thing because they are not balanced at manufacturing.
>>>>>>>>>>>>>Action
Old 11-08-2013, 11:15 AM   #18
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Bruce,
Thanks for info, makes sense can't balance a moving target. Steel lug inserts, my truck doesn't have that AFAIK. Direct contact with the wheel supplier safety something, very good sign.
Thanks.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
