Old 03-22-2009, 02:54 PM   #1
1978 25' Tradewind
Antioch , California
Aluminum Wheel Source
I am trying to locate some either 15" or 16" aluminum wheels with a center bore of 3 1/2 inches. Most trailer wheels on EBay seem to have a bore diameter of 4.25 inches. Currently, my Airstream rides high in the nose due to a fixed load equalizing hitch, thus my interest in 16" wheels.
sail4.0 is offline   Reply With Quote
Old 03-22-2009, 03:00 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
Why not check out installing a 'taller' (larger outer diameter) tire for your existing wheels...you'll have to check to see how much clearance you need in the fender wells...check with a local tire dealer/specialist.
Ray & Pat; Morada, CA
Old 03-22-2009, 04:24 PM   #3
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Why not drop the ball heigth to allow the front of the trailer to ride level.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 03-22-2009, 04:53 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
You will find the wheels you are looking for here.
http://www.trailertiresandwheels.net...78/page/910764
However you go you want to get that trailer level. Running an Airstream tongue high puts additional load on the TV and will eventually do damage to the rear axle because of overloading it.
Airstreams do not have any compensation system between the axles and if not level overloads one or the other axle depending on tongue high or tongue low.
2004 Excursion 4x4
Old 03-22-2009, 08:07 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
How big a tire do you need? There is not a lot of space between the wheels on a typical 70's Airstream to begin with. If you get a new truck next year and the reciever is lower, would you then look for smaller tires?
The problem is the hitch is too high, I would replace the drop down bar for the hitch with an adjustable one.
Richard
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Good source for aluminum... malconium Ribs, Skins & Rivets 18 07-31-2009 08:05 AM
Aluminum Source Sundance Ribs, Skins & Rivets 9 08-02-2007 09:46 AM
source for stamped aluminum skin str8strm Cabinets, Counter Tops & Furnishings 2 11-03-2005 10:28 AM
Another aluminum source 83Excella Ribs, Skins & Rivets 0 05-14-2002 11:34 AM
