Old 03-01-2013, 10:43 AM   #1
1974 25' Tradewind
2000 34' Limited S/O
cottontown , Tennessee
Aluminum wheel
Need suggestions on replacing wheels on 34 slide out. has alcoa 15'' but two wheels have been replaced with white trailer wheels. need 2 alcoa 5 spoke 6 lug wheels or 6 good replacements will imported wheels hold up. weight 10,000 lbs thanks
shamrock is offline   Reply With Quote
Old 03-01-2013, 11:52 AM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I just bought six of these for our 34'
ST-0456655 15 x 6 Star Aluminum Trailer Wheel , 6 on 5.50 bolt pattern, 2540 lb Capacity
According to the manufacturers website each wheel is rated at 2850#
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 03-01-2013, 12:55 PM   #3
steverino's Avatar
2018 30' Classic
Ivins , Utah
I'll be replacing my 15" 5-spoke wheels with 16" within a couple weeks. They're the wheels typically delivered with late model flying clouds. But only 4 available. Please let me know via IM if interested.
steverino is offline   Reply With Quote
Old 03-01-2013, 02:32 PM   #4
ddruker's Avatar
2000 27' Safari
Palo Alto , California
I just bought four of these...
16 Inch Sendel T05-66655SM.
I like that they have machined inserts that match the rest of the wheel and cover up the lug nuts, instead of the standard chrome dome hub cover.
- Dan
1999 27' Safari + 2011 Mercedes GL 350 Turbo-diesel
ddruker is offline   Reply With Quote
Old 03-01-2013, 04:58 PM   #5
Baltimore , Maryland
Folks, a word of caution... When you put those aluminum wheels on, make sure you check the lugs every 50 miles for the first 350 miles. I am currently repairing EXTENSIVE damage caused by a (now) customer not being told this when they had the fancy new wheels put on. Two loose lugs and the studs will quickly saw right through the rim throwing it from the hub. I am amazed at the amount of damage this cause.
Old 03-01-2013, 05:15 PM   #6
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Thanks Frank, I will keep an eye on them.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
