Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels
Old 10-22-2009, 04:48 PM   #1
Profile:  1985 31' Excella
battle ground, , Washington
alloy wheel center cap corrosion
Hey all, I just scored a set of airstream alloy wheels that match the originals on my 85 excella; the center caps appear to be "corroded in place." I sprayed the parting line with wd40 and have whacked them with a dead-blow hammer-but nothing is moving, yet. Any suggestions?
wmarsha is offline   Reply With Quote
Old 10-22-2009, 08:08 PM   #2
Commercial Vendor
vinstream's Avatar
Profile:  1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Are you sure there is not a "set ring" or "set screw" If they are "corroded" as you say try one of two things. First, try B'LASTER (1-800-858-6605) no web site. Or second, heat! Heat up the cap and wen it cools it may pop the out....
Good Luck!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
vinstream is offline   Reply With Quote
Is this a wheel cap? If so, where do I get one? Aage Wheels 7 10-15-2009 07:39 PM
Need wheel backspacing info and weight cap suggestion GoMopar440 Wheels 6 01-07-2009 05:11 PM
Sizes Dust cover cap, wheel bolts Lothlorian Wheels 5 06-19-2008 09:47 PM
where to find wheel center cap tslanier Wheels 4 04-03-2007 07:11 PM
Argosy Hub Cap/Wheel Cover COArgosy78 Parts Archive 11 08-12-2004 10:33 AM
