Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels, Hubs & Bearings
Old 07-14-2014, 05:04 PM   #1
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
All metal valve stem TR542 for Alcoa rims 2001-06
I'm making this post mostly for somebody's future reference, maybe they will pick up this thread in a search, and maybe I can also get rid of some valve stems along the way
I recently had new tires put on my 2001 '34 Limited, it has slotted Alcoa forged aluminum 15"rims. I requested the tire dealer replace the rubber valve stems with some nice metal ones. To make a long story short, the dealer did'nt have any small enough to fit in the hole of the Alcoa rim. I went home and did my home work and found out that Airstream used these particular Alcoa rims on certain trailers from 2001-2006, the diameter of the valve stem hole is a small .375" hole (compared to the standard .453" hole in most rims) It is called a TR 542 stem. While this really should have been something I thought the "tire guy" should have known, he did'nt and I ended up ordering some from Myers Tire Supply in Akron,OH. (The company that Airstream recommended I purchase them from. The only problem was they had a minimum $25 order and while these little stems are of very high quality, they are actually really inexpensive for metal stems. (at least I thought they were pretty cheap!) I ended up having to buy 17 of them. So I have 11 available. I figured maybe someone on the Forums might be in the market and I could save someone some grief. $2.00 each, shipping included and I have a total of 11 available. Once again, they are made for the Alcoa forged aluminum rims with the small .375" stem opening found on 2001-2006 rims. Mail me at toddbecker1@gmail.com or 316-250-6371 My name is Todd.
I also have these listed in the classifieds, but figured I make a post here in case anyone is interested in maybe just having 1 or 2 as a spare. Certainly couldn't hurt...
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 11-17-2014, 11:25 AM   #2
Ronman's Avatar
2007 27' Safari FB SE
Rancho Murieta , California
Todd,
I have a 2007 27FB Safari and I am looking to replace my stems. how would I know if my rims have the smaller hole? If I knew that they did, I would have interest in purchasing 4.
Thanks!
Ron
Ronman is offline   Reply With Quote
Alcoa valve stem?? Need help.... truxpin Wheels, Hubs & Bearings 2 07-07-2014 07:25 PM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 08:40 AM
Valve stem failure on '02 Bambi dtbw Wheels, Hubs & Bearings 12 10-25-2003 10:17 AM
Valve stem Craig Wheels, Hubs & Bearings 1 08-04-2003 05:34 PM
