Old 04-02-2011, 08:25 PM   #1
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Aftermarket aluminum rims for '70s models?
Has anyone purchased a set of aftermarket aluminum rims for a 1970's Airstream (6 bolt, 15" rims)? If so, what make and model did you purchase and where did you find them?
I'm also wondering the specs on these 1970's rims (eg.offset). Anyone have the specs?
Kevin
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 04-02-2011, 08:47 PM   #2
x
XXXX , XXXX
Kevin these will fit. The site lists all the psecs you need for your trailer rim size. If you don't like that style or supplier just use the specs and look for different wheels. They have rim & tire packages which come mounted and balanced.
Aluminum Trailer Wheel Style: SERIES #03 Size: 15 x 6 Bolt Pattern: 6 x 5.5 Bore Size: 4.25 Load Rating: 2830 lbs @ 80 PSI Offset: 0mm Hispec
wasagachris is offline   Reply With Quote
Old 04-02-2011, 09:32 PM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Kevin,
Here are a few. My favorite is this one. But that is a move to 16" rims.
Lance
Top is offline   Reply With Quote
Old 04-03-2011, 09:07 AM   #4
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Kevin,
you can also find them at www.tredit.com. I am told theses are the suppliers for Airstream
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-03-2011, 08:17 PM   #5
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
I have purchased two sets of wheels from the company listed I. The second post. They were very helpful and knowledgable, the also seem to understand Airstreams. The wheels I purchased we're HSW (High Spec Wheels). FWIW they are, from what I understand, one of the larger suppliers of OEM Alum. Wheels to the RV industry. I have been very happy with the wheels on both my AS and my previous SOB.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 04-04-2011, 07:46 AM   #6
Soyboy's Avatar
1999 28' Excella
Images: 44
Just to clarify, I had a bit of a typo in my first sentence in my post from last night (late night postings are bad sometimes!). I purchased my wheels from Trailer Tires and Wheels as linked in the post by Wasagachris (the second in this tread). The other places may be fine too. You will find that a number of places sell HWT wheels (I posted them as HSW in my post above). You can, if you are careful about the weight ratings, run "truck" aftermarket alum wheels on your trailer. The choices are a bit limited however when trying to stay in they proper weight range/wheel bolt pattern/offset. Again I found Trailer Tires and Wheels to be very helpful in making sure I got the correct fit. Of course I don't know about shipping to the OP's home in Canada, but I am sure you can ask if they will do it.
BTW here is a link to HWT wheels main website if you are interested.
When ordering wheels don't forget the center caps, get stainless steel rather than chrome if you can. The cheaper chrome ones will start to rust right away. Also get stainless lug nuts rather than steel with chrome caps as the chrome ones will also start to rust quickly.
I do have a photo of my trailer on a recent trip to Assateague in my gallery that, if you supersize it, will give you an idea of what "mod"/ modular style wheels look like. I think they look great, but that of course is subjective (vintage folks tend to hate alum wheels in my experience :-) ). You also want to make sure you put in high pressure tire valves too.
BTW, I put new sets of Maxxis tires on both of the sets I have purchased over the past couple of years. I purchased the tires from Discount Tire Direct.
1999 28' Safari
TAC MD-6
AIR 4534
Old 04-04-2011, 01:13 PM   #7
1988 29' Excella
Livingston , Texas
Howdy!
I would aslo recommend Trailer Tire and Wheel Suppermarket, have used them twice and have been a great company to deal with. I just order four (4) new tires for our AS and they beat the price of anyone local even with their shipping cost.
"Happy Trails"
chiefneon
chiefneon is offline   Reply With Quote
Old 04-09-2011, 08:25 AM   #8
kevin242's Avatar
1977 25' Tradewind
Thanks for the info everyone!
Old 04-25-2011, 11:02 AM   #9
1965 Overlander NJ
NJ_1965's Avatar
1965 26' Overlander
Hillsborough , New Jersey
I bought a set of 4 aluminum wheels from trailerandtruckparts.com. No shipping on orders over $99.
15 inch Trailer Rims, Aluminum, Chrome, Steel and Galvanized Trailer Wheels
I bought the 15 inch T04 Black Machined Aluminum Trailer Wheel 6 on 5 1/2
Item Id: ST-T04-56655BM. $89.99 each
They have a load capacity of 2,830 lbs.
They look nice too.
15 inch 5 Lug Black Machined T04 Aluminum Trailer Wheel
NJ_1965 is offline   Reply With Quote
aluminum, mags, offset, rims
Aluminum desk top worksology Cabinets, Counter Tops & Furnishings 33 06-30-2011 05:47 AM
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 08:08 PM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 10:38 PM
Replacing Steel Wheels with Aluminum crookedroad Wheels, Hubs & Bearings 8 02-03-2011 11:27 AM
