Old 06-22-2010, 06:43 PM   #1
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
'76 28ft Argosy Wheel Bearings
I am collecting the trailer on Saturday. The owners son is selling it for his mum but is not interested in helping out with prepping the trailer and is not going to be available for handover. The mum has no clue about the trailer (she lost her husband last year)
I will need to repack the bearings (at least) but my dilemma is that this is in a pretty remote area and the closest NAPA is a couple of hours drive.
I believe the axles are original.
Can anyone supply the (best guess) bearing/seal part number so I can get them from my local Commercial Bearing or NAPA (I have accounts and can return unused no problem) Any other things to be concerned about with this? They were re-packed 2 years ago but it has not moved since then.
Getting down to the wire now. I am spending Friday making the journey, Saturday prepping and Sunday for the return.
I hope it's worth it.
Bex
Bex is offline   Reply With Quote
Old 06-22-2010, 06:56 PM   #2
tpi
Trabuco Canyon , California
Just a wild guess based on what my '05 takes and Inland RV catalog. Assuming 12X2 brake drums.
Inner bearing 25580
Seal 10-36
Outer bearing could be several, and they use different races: 15123 for the heavier axles, or LM67048 for the 5200 lb axles. I would not interchange the different bearings without changing the races.
I would trust someone with experience with your model or vintage long before this post, but it may give you something to google or start with.
tpi is offline   Reply With Quote
Old 06-23-2010, 10:23 PM   #3
Bex
1976 Argosy 28
Thanks for the suggestion. I will go with it for lack of any other information. I appreciate it. I got back in touch with the sellers son today and he assures me I will not need to replace the bearings, or indeed repack them. It has not been pulled for close to two years so I am sure they will need re-packing.
Cheers
Bex
Old 06-23-2010, 10:39 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, if they have documents showing that a shop did the repack two years ago, I would tow it home as is; And check it for yourself after. I would be more concerned with the condition of the tires.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-24-2010, 05:07 AM   #5
Bex
1976 Argosy 28
The PO did it himself, so no docs.
I will drop one wheel and check.
Thanks!
Bex
Wheel bearings Allen H Axles 18 10-31-2007 04:12 PM
Wheel bearings FlyingW Axles 3 07-01-2006 05:36 PM
Wheel Bearings 76ArgosyDave Axles 7 06-29-2005 03:00 PM
Repacking Wheel Bearings Buttercup Axles 38 05-07-2005 08:57 PM
Wheel Bearings 85MH325 Axles 5 04-05-2004 06:41 AM
