Originally Posted by Haoleman
Hey Andy,
I'm looking at a 1973 Safari 23. What type of wheels would it have? Splits with tube tires or tubless? Also, If I buy it what would work both in a steel wheel and mag wheel?
The coach should use non-split wheels, and tubeless tires. Do you have a single or dual axle Safari?
Bolt pattern is 6 on 5 1/2", zero offest, and a weight capacity u-pwards of 2300 pounds each. If you have a single axle, you would need load range D tires, dual axle, you can use load range C.
