Old 08-26-2005, 02:57 PM   #1
4 Bolt Rims
Looking for a set of 13" rims for a 61 Bambi. 4 bolt pattern with 4.5" diag. center to center. Can anyone help me find rims like this or is it possible to change the hubs to a 5 bolt pattern that would be easier to find?
hihosilvr is offline   Reply With Quote
Old 08-26-2005, 04:22 PM   #2
You will have much greater luck by changing the drums to 5 lug. However finding a drum that uses the small bearings will add to the hunt.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-26-2005, 06:11 PM   #3
Andy,
Any ideas as to where I might look for the 5 bolt hubs that use small bearings?
Old 08-26-2005, 06:30 PM   #4
Get the bearing numbers.
Then make a post on this site of what you want.
There could be someone out there with them.
Or, find and old parts only Airstream. Where? Who knows.
If everything fails, you could, but at a large expense, upgrade with a new axle.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-26-2005, 07:41 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I would try Southwest Wheel in Dallas, TX. Call them, the sales people have more information than the website. I found them knowledgeable and helpful. If you decide to change bolt pattern, you may find it easier to replace the axles with new, your axle is spring and not torsion, correct. Then you can obtain new brakes and any bolt pattern you want. On my 1954 Liner, I decided to replace the axles since I could not easily locate brakes for the 1954 axles and eventually want to upgrade to discs.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 08-26-2005, 08:38 PM   #6
RichardT's Avatar
What kind of rims do you have currently? Are they damaged?
RichardT is offline   Reply With Quote
Old 08-27-2005, 08:24 AM   #7
The axle is torsion. Looks as though it has been welded to the frame. I have two rims now but they are not the same and I would like to have a spare. Maybe a new axle is in order. Any ideas on axle type?
Old 08-27-2005, 08:49 AM   #8
greg176's Avatar
Gabriola Island , British Columbia
I would check the axle condition first.Check the axle info at inlandrv.com.I got a great deal on a new axle from Standens in Calgary.Or maybe a trip to Axis see this thread:
http://www.airforums.com/forum...ad.php?t=16811
greg176 is offline   Reply With Quote
Old 08-27-2005, 07:50 PM   #9
61Bambi's Avatar
4 bolt rims
The Bambi 4 bolt wheels are early Ford Falcon and 6 cylinder Mustang wheels. You can get them in both 13" and 14" sizes from vintage car part suppliers. I believe that they were only rated for 1100lbs. I recently put 14's on my Bambi. Its a tight fit but they work. (Going to 5 bolt would certainly be better).
61Bambi is offline   Reply With Quote
Old 08-29-2005, 03:53 PM   #10
Investigate all of your options before doing anything.
A few questions you can ask yourself are:
What condition is the axle?
If it is good, do I want to replace it?
Can I get the wheels?
If I can, how much are they in relation to a new axle and new wheels.
The cost of a new axle does not have to be expensive. I know, I have done it. Several others on here have done it and most have used local axle shops to do it. You can get an axle at a reasonable price and it is worth it whether you decide to keep the trailer or sell it.
Anon is offline   Reply With Quote
Old 08-31-2005, 08:57 AM   #11
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If you change the axle you will still have to buy rims. Although you will find it is easier to get the 5 hole rims.
>>>>>>>>>>>>>>Action
Old 08-31-2005, 03:03 PM   #12
>>>>>>>>>>>>>>Action
I believe that is what I had said in my last question....
Old 12-01-2005, 11:11 PM   #13
RichardT's Avatar
What lug pattern were 63 Bambis, also what is a 1963 Bambi tire size when new?
PS: I need a 5 lug 13" wheel to use as a spare for my 1963 Bambi if you have one PM me.
Old 06-05-2006, 04:55 PM   #14
1963 16' Bambi
Oxford , Oxford UK
hi
did you get n ansewer to this. Im in the similar posotion have a 1963 bambi want to get her new wheels... what did you do ?let me know ! Thanks Mary
marypie is offline   Reply With Quote
Old 06-05-2006, 09:18 PM   #15
1960 24' Tradewind
santa barbara , California
Stockton Wheel in Sacramento CA makes wheels.Thats what they do .The wheels are professionally made .They have all the tooling and machines needed to build wheels.GreenBall tires in Long Beach CA that offers trailer wheels for all types of applications ,industrial ,commercial,trailer ,many many applications ,you can go to GreenBallTires online and look for your size of wheel .the towmaster tire is a good tire also they sell ,comes on many boat trailers .pattersontoo's advice is correct ,first thing to do.
Scott
scottanlily is offline   Reply With Quote
Old 06-06-2006, 10:10 AM   #16
Somewhere , Indiana
Wheel Vintiques!!!
Wheel Vintiques does a nice job manufacturing wheels also. They also have the "cool" baby moons available. A bit pricey - but sweet!
Regards,
Henry
axleman is offline   Reply With Quote
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
deadbolt with inside twist style lock CindyH Doors & Locks 4 10-16-2002 08:58 PM
dead bolt joel Doors & Locks 1 08-25-2002 08:35 PM
Mags Or New Rims?? Charcigar Wheels, Hubs & Bearings 10 08-01-2002 05:09 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
