Old 04-14-2012, 06:41 AM   #1
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
23'FB FC. Has 14" wheels..
I have the GYMs on my new 2011 23' FB FC. I believe they are 14".
Any suggestions on tires? I've got a little homework to do.
Maybe I can find a 14" Michelin. I can't imagine a 16" would fit..
I sure don't see any reason to go to the 15" tires/wheels everyone is having problems with. (I know, I shouldn't say "everyone")
I plan on an Alaska trip in the next few years. Seems like a little less to worry about.
Do the 14" GYMs have any better track record?
Jeff
GettinAway is offline   Reply With Quote
Old 04-15-2012, 06:02 AM   #2
GettinAway's Avatar
Thinking a little more on this.. Maybe putting the 15" wheels on with appropriate tires, might be ok.. They must certainly have a higher load rating than the 14s I have on there now.
Plus, maybe there is someone out there that just went from 15" to 16", and maybe they want to sell them?
I think I'd still like to get away from the Marathons, and I'm not even sure a 15" would fit on a 23 FB, if someone has answers, I'm curious.
Jeff
Old 04-15-2012, 06:19 AM   #3
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
14" just doesn't sound right. It really should have 15"s from the factory.
Tom
mutcth is offline   Reply With Quote
Old 04-15-2012, 06:23 AM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Factory specs say 14". I'm surprised they're not 15"
Old 04-15-2012, 07:12 AM   #5
Connellsville , Pennsylvania
We looked at a couple new 2012 23's recently. I was shocked also to see them sitting on 14's.
Midnightmoon is offline   Reply With Quote
Old 04-15-2012, 07:28 AM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I'm surprised also. When I see 14" wheels, I think boat trailer. Do they have a 5 or 6 bolt pattern?
Brian
SuEllyn & Brian McCabe
Old 04-15-2012, 07:31 AM   #7
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Jeff
My 1997 25' Safari came with 14" GYM and the experience was dreadful. The problems were resolved completely by replacing them with 15" wheels and Michelin LT. The only difficulty was finding a 15" wheel with a 14" wheel bolt pattern. The upgrade to 16" would be awesome and most likely result in worry free traveling.
Jim Flower is offline   Reply With Quote
Old 04-15-2012, 07:53 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The 23's also have smaller 10" brakes to fit the 14" wheels than the larger trailers.
doug k
Old 04-15-2012, 07:54 AM   #9
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
We are our tires' worst enemy. We don't protect them from the sun, or from dew and overnight condensation, or from under-inflation and we don't put quality valve stems on them. We don't keep them balanced and rotated. And we let them sit for months without turning them. Then we blame Goodyear for short life and sidewall failures.
JBinKC is offline   Reply With Quote
Old 04-15-2012, 08:26 AM   #10
fmrcaptevil's Avatar
Weldon Spring , Missouri
...and we routinely exceed 65mph.
You mess with me, you mess with the whole trailer park.
fmrcaptevil is offline   Reply With Quote
Old 04-15-2012, 08:41 AM   #11
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Measure twice ...
My '99 Safari 23' came with 14" wheels and GYMs (I purchased it used) and I had zero problems with them. At some point, due to the tires' age, I replaced them with new 14" GYMs and again had zero problems.
It may be worth noting that I am a stickler for air pressure monitoring and use an infrared thermometer on every tire and hub at every stop. About a thousand years ago, I sold tires, and I learned early on that most - not all, but most - tire failures are the result of underinflation. Often due to something like a slow leak around an embedded nail, etc. that goes unnoticed for a day or two while the tire pressure slowly bleeds down. The result of careful monitoring, etc. is that over many decades of driving and towing, I've only once had a catastrophic tire failure, and it was on an auto, not a trailer.
But it seemed to me that larger and higher speed rated tires would give me more "margin of error" ... this was mostly unscientific, though I'd read dozens of articles on the subject. So ultimately I decided to replace the GYMs with 15" Michelin LT tires (LT 235 75 R15) ... and of course new wheels and all-metal valve stems, etc. These are LR "C" tires, and at 45 psi each has a load rating of 1785 lbs as opposed to the 14" GYMs load rating of 1760 at 50 psi. And of course, they have a higher speed rating.
I've been totally satisfied ... BUT ... here's where the "measure twice" bit comes in: they only have about 1" - 1 1/2" of clearance fore and aft in the wheel wells. And the larger tire / rim assembly BARELY fits into the spare tire carrier. So if you are gonna' go that route, I strongly suggest that you check out the inflated diameter and section width of the proposed new tires and measure carefully before pressing the "go" button. It might be worth talking to a trailer specialist to make sure that the proposed wheels have the correct offset, etc. also.
One other potential issue is that the slightly larger tires have slightly more leverage against the original 10" brakes, so in theory at least, the brakes are a bit "weaker." This has not so far proved to be a problem for me, even with a lot of mountain driving, but they need to be maintained in a good state of adjustment.
Good luck with your decision!
AirsDream is offline   Reply With Quote
Old 04-15-2012, 08:44 AM   #12
Gainesville , Florida
Good post, thanks for the info. jim
Old 04-15-2012, 02:49 PM   #13
GettinAway's Avatar
All good info. Thanks
I've only had the 23FB for a month.
I'd like to avoid a bunch of tire issues if I could, but I think I will wait and see how the 14's do.
Old 05-31-2012, 06:30 PM   #14
Alumitater's Avatar
2007 25' Safari
Spanish Fort , Alabama
15" wheels
I have four 15" aluminum wheels which came off my 2007 25 Safari when I replaced them with 16" wheels at Jackson Center. They are 6-bolt pattern and were mounted with Goodyear 225/75/15 tires. They are sitting idle in my backyard. If you decide to try out 15's holler at me and perhaps we could work out a price. Have no idea about shipping costs, but could explore. Tom
ID:	159758   Click image for larger version
Tom and Robin
2007 Safari 25' FB Twin
"If you have to go through a minefield....follow somebody"
Alumitater is offline   Reply With Quote
