Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Wheels, Hubs & Bearings
Old 04-28-2009, 06:32 PM   #1
Moderator Emeritus
overlander64's Avatar
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
1964 Airstream Lug Nut Specifications
It is time for new tires on my Overlander, and rather than go through all of the sanding and repainting I decided to splurge on a new set of aluminum wheels. I have everthing ready to go for my appointment to have the wheels and new Carlisle tires mounted on the coach tomorrow afternoon. The one exception is the lug nuts (yes, I double-checked, and my coach does have lug nuts rather than lug bolts) -- I need to know the specifications for the lug nut prior to leaving for the appointment as the tire dealer from whom I am purchasing the tires does not have lug nuts and I will have to bring them with me. Primarily, I need the size and thread count.
My coach has its original Henschen axles (or they are at least 20 years old).
Kevin
P.S.: I also splurged on a complete set of Centramatics for the coach as well.
Kevin D. Allen
AIR #827
1964 Overlander International
1964, lugs, lug_nuts, nuts, size
Lug Nut Caps woodedareas Wheels, Hubs & Bearings 13 05-25-2008 03:48 PM
Lug nut size Whirlaway Wheels, Hubs & Bearings 4 04-17-2007 07:10 PM
Lug Nut Torque alan Wheels, Hubs & Bearings 46 11-27-2006 09:32 PM
Lug Nut Socket Help... AZstreamin Wheels, Hubs & Bearings 20 09-21-2006 06:04 AM
Lug Nut Size?? Steve Heywood 1997 -2001 Excella 3 08-16-2005 12:24 PM
