Old 10-30-2014, 03:01 PM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Switched to 15" LTX (P) 235/75R15 XL Michelins on the 15" factory rims for our 2013 25FB International as soon as I got it home. The Classic was immediately upgraded to the 16" SenDel T03-66655T wheels and the 16" LT225/75R16/E LTX M/S2 Michelins. The Classic's spare was mounted on a SenDel S62-66655SG galvanized steel wheel. I have a spare SenDel aluminum wheel in storage.
There was no need to alter the spare tire storage rack arms on the Classic.
Old 10-30-2014, 03:21 PM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The reliability of the 16" Michelins is so good you most probably will never use the spare. Only real chance is picking up a nail somewhere. Even then the original spare is more than adequate to move you down the road until you can get the flat fixed or replaced.
And there is no particular rush for that. Your Airstream Owners Manual for tandem axle trailers allows you to take off a flat tire and proceed at reduced speed for a limited distance on the three remaining wheels to have it repaired.
We kept the original spare and replaced four wheels/tires.
Doug and Cheryl
Old 10-30-2014, 03:24 PM   #17
dznf0g's Avatar
Oswego , Illinois
Yeah, except for the crappy rubber/metal high pressure stems that DT put in while mounting and balancing my Michelins. 3 of 4 failed out west summer of 13. Used spare on two of the failures. 3rd happened at an exit and just happened to be a tire store at the bottom.
Have all steel stems now.
-Rich-
Old 10-30-2014, 03:42 PM   #18
dkottum's Avatar
Agree, steel valve stems must be part of the package.
Doug and Cheryl
Old 10-30-2014, 04:06 PM   #19
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Just got Lucy's tire and wheel package a few minutes ago via FedEx. I have already unpacked them for inspection. They look great.
SuEllyn accused me of being mentally ill because I wanted to take some pictures of Lucy's new tires to post on the Forums. So, guess what, here they are.
Now I'm waiting for the Centramatics to arrive.
Brian
ID:	225402   Click image for larger version
SuEllyn & Brian McCabe
Old 10-30-2014, 06:58 PM   #20
dznf0g's Avatar
Oswego , Illinois
Chuckle, chuckle. We're all a bit mentally ill to find a certain beauty and pleasure in something as benign as tires and wheels, but....."that's all I got to say 'bout that..."
-Rich-
Old 10-30-2014, 08:43 PM   #21
2014 27' Flying Cloud
Wenatchee , Washington
I wish more people were concerned about traffic safety.
2012 Ram 3500 CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
21Airstream is offline   Reply With Quote
Old 11-02-2014, 10:25 AM   #22
Balancing a new tire and wheel is nice, but that does not take care of the hub and drum.
Two things a person can do.
1. Find a shop that can balance the tire, wheel hub and drum as an assembly.
2. Balance the tire and wheel, and then install Centramatic balancers.
I am amazed at the demand for the Centramatics.
Seldom do you ever see a product that is so cheap, and yet does so much, especially for peace of mind.
Old 11-02-2014, 03:34 PM   #23
moosetags's Avatar
Old Lucy had the 16" Michelins with the Centramatic balancers. I put 60,000 miles on those tires without ever rotating them. When I traded Old Lucy in, those tires hardly showed any tread wear, and I never had a single issue with them.
Brian
Old 02-01-2016, 05:57 AM   #24
'15 Flying Loud 20' Bambi
renderit's Avatar
2014 16' Sport
small city outside a big one , south of some, north of some
I have a 2015 20' single axle. Ran it last year up to the mountains, probably 4000 miles and maybe 500 since. I have been reading all of these threads and trying to figure out all this stuff. I certainly don't want to find out the hard way I should have changed them out.
Can ANYBODY tell me what to get EXACTLY? Include the Centramatics. And where is a good place to get them. I would assume full load as I'll bet I get pretty close at times. Include info like steel stems etc. I am really tire stupid and y'all are making me feel stupider. More stupid? Exceedingly stoopid?
renderit is offline   Reply With Quote
Old 02-01-2016, 08:31 AM   #25
renderit's Avatar
2014 16' Sport
Dug through a bunch of stuff and got my answer. Michelin LTXMS2 225/75R16 E rating with Sendel T03-66655 (I did BM for black accents), Centramatic 200-221Special, and Einkey Valve stems. And the search feature was worthless...
Old 02-02-2016, 06:49 AM   #26
switz's Avatar
2014 31' Classic
Images: 8
Since you are going with 16" tires and wheels, the two six lug bolt pattern Centramatic models are the same price. I would suggest the larger diameter "#300-356 all A plates" to gain additional balancing capacity.
Centramatic Part Numbers for Airstream use:
14" 5 bolt pattern #200-221 standard part
15" 6 bolt pattern #200-221 Special
16" 6 bolt pattern #300-356 all A plates
Old 02-02-2016, 07:29 AM   #27
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
16" Wheels on 2015
Where does one purchase and get Centramatics installed?
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 02-02-2016, 07:36 AM   #28
2016 30' Flying Cloud
Oviedo , Florida
I keep seeing the reference to "all A plates" on the 300-356 but can find no reference to that on the Centramatic website or anywhere else. What is the difference?
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
From 14" wheels to 16" wheels Air Cruiser Wheels, Hubs & Bearings 24 09-16-2011 07:18 AM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
